1977 c6 governor problem
Old Dec 12, 2011 | 10:07 PM
400inatruck's Avatar
400inatruck
My transmission will kick down a gear without me putting my foot through the pedal. I don't engage the tranny kickdown. I have checked and reset the modulator valve, nothing helps. It will kick down a gear for a split second then shift back up, like it's mini stalling. I've checked everything on the motor, carb, and etc. I was told by an Oreilly's parts salesman that it is probably the secondary governor.
Old Dec 13, 2011 | 01:31 PM
stuart1's Avatar
stuart1
If you have a restricted line anywhere it causes vacuum to be depleted for a split second and that can cause it.
On some trucks the primary governor weight is a great big honking **** and the secondary has an extra plug installed.
The valves can be installed from a different governor or the entire assembly can be changed.
Old Dec 13, 2011 | 10:06 PM
400inatruck
where are all the vacuum lines running to the transmission? I know of the modulator one.
Old Dec 13, 2011 | 10:54 PM
stuart1's Avatar
stuart1
By vacuum lines I mean all vacuum lines, not just to the transmission.
Old Dec 14, 2011 | 06:58 PM
400inatruck
the only vacuum lines I have hooked up are: the modulator line, the power brakes, and one for distributor advance.
alchemist1
Oct 24, 2014 02:51 PM
Redneckfordf2502002
Feb 26, 2014 04:09 PM
IHI
Nov 29, 2007 06:36 PM
TailGater_73F100
Sep 17, 2004 08:55 PM
