Hubs question
Old Jun 25, 2023 | 09:06 AM
Mick83's Avatar
Mick83
Hubs question
I have had or have five Ford 4WD trucks.
Three of them had hubs that were either locked or free, and had to be changed manually.
One has automatic locking hubs that apparently lock in automatically when I select 4WD from inside the truck. No way to physically manipulate the hubs.
The new 2022 Lariat 350 has hubs that say locked and automatic. They get changed physically like the locked and free hubs.
I don't get it.
Can someone please explain to what I need to do in order to get into and out of 4WD with this hub system.
Thank you.
BTW, this truck has a 7.3 gas engine and I got 19 mpg on my last 180 mile trip, mostly highway but some stop and go.
I am certainly satisfied with that; I get 11 mpg in my 2002 250 6:8 V 10.
Old Jun 25, 2023 | 09:29 AM
shawnee1's Avatar
shawnee1
Leave them in the auto position and the hubs will lock when you select 4WD. The lock position is used in the event the auto locking system fails or if you want a faster response when engaging 4WD.
Old Jun 25, 2023 | 10:05 AM
fordman19762003's Avatar
fordman19762003
This pretty much sums it up. I believe the book says that if you are plowing snow or doing heavy off roading to manually lock them in also.
I special ordered my last two trucks so I could get the full manual system because I think it's the most bullet proof set up currently offered. I don't know what I'll do when I decided to get a new truck, guess I'll have to go back to the electronic system.
Old Jun 25, 2023 | 11:22 AM
scraprat's Avatar
scraprat
Top Answer: 5
Only thing with the hubs now and the convenience of the auto engage in the truck is that the hubs should be exercised periodically just by turning the hub controll **** back and forth. I'll do mine once a month so they don't freeze up.
Old Jun 25, 2023 | 11:45 AM
RidgwaySD's Avatar
RidgwaySD
Do what I do and lock the hubs manually, ignore the auto system... I use 4wd a lot. I plow snow, I drive in 5-6 months of winter, I run lots of steep gravel mtn roads in the summer. I still find the auto doesn't work every time, or as quickly as I would like sometimes. If I need 4wd I manually turn them. If it is more of a maybe with low consequence i will use auto and usually it works fine.
Old Jun 26, 2023 | 07:47 AM
GAZZILLA's Avatar
GAZZILLA
I only manually lock them if 4WD is going to be needed for an extended period or if the conditions are extreme. I believe leaving them locked reduced mpg.
Old Jun 26, 2023 | 08:45 AM
ToMang07's Avatar
ToMang07
Old Jun 26, 2023 | 08:48 AM
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by ToMang07
How dare you suggest the owners manual in to this thread.
Old Jun 26, 2023 | 09:45 AM
Mick83's Avatar
Mick83
The problem with owner's manuals these days, especially truck manuals, is that they apply to many other vehicles besides the one you bought.
With the amount of options and features available on each of six plus trim levels, it's hard to determine if what the manual says applies to your vehicle, "if equipped".
Old Jun 26, 2023 | 09:59 AM
ToMang07's Avatar
ToMang07
And yet these hubs work the exact same as they all have in the last 20+ years....
Old Jun 26, 2023 | 10:15 AM
Gomerpyle's Avatar
Gomerpyle
Always read the owners manual, just bypass the 300 pages about how to wear a seatbelt & it's very informative.
Old Jun 26, 2023 | 12:08 PM
Albertaoil's Avatar
Albertaoil
My 21' is on the third set of locking hubs all under warranty. The hubs the truck came with and the second set did not last long at all but this third set has been holding up for a few months now. My next step will be to bypass the auto system and install a set of WARN hubs and be done with it.
Old Jun 26, 2023 | 02:56 PM
Mick83's Avatar
Mick83
I disagree. Not exactly the same.
Locked is still locked, but automatic is not the same as free.
Old Jun 26, 2023 | 03:14 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
There were Auto/Lock hubs 20 years ago on these trucks, so yes, they work the same as they did 20 years ago.
Old Jun 26, 2023 | 03:19 PM
Rwhjr's Avatar
Rwhjr
Yeah not to mention regardless it’s the same functioning dial. Just a slight change over the past couple decades lol.
So if you’ve happened to read one in that timeframe you’re good lol.
