Hubs question
Old Jun 26, 2023 | 03:25 PM
Mick83's Avatar
Mick83
Maybe they existed, but I did not have them. The first three trucks I owned, beginning in1981, had hubs with two options: locked and free. And free is not the same as automatic.
That''s all I am saying.
Old Jun 26, 2023 | 03:31 PM
scraprat's Avatar
scraprat
Top Answer: 5
Is it because you had a shifter on the floor and had to go out and lock the hubs to have 4 wheel drive. Whereas of now there is auto on the hubs with a **** on the dash for 4 wheel drive. No need to go out and lock the hubs unless the auto feature stops working.
Old Jun 26, 2023 | 03:40 PM
Mick83's Avatar
Mick83
Yes. My 1981 and 86 had separate drive shifters, as well as a standard 4 speed transmission shifter. Even the 2002 250, which has an automatic transmission, has a transfer case shifter on the floor.
Old Jun 26, 2023 | 03:49 PM
Mick83's Avatar
Mick83
If the 250 hubs are in free, and I put the transfer case in 4WD, obviously the truck will not be in 4WD, because the hubs are not locked.
If the 350 hubs are in automatic, and I put the transfer case in 4WD, the truck will be in 4WD (providing the autolocking hubs work).
Therefore the free mode on my 250 is not the exact same as the automatic mode on my 350.
That's the only point I am trying to make.
Old Jun 26, 2023 | 03:54 PM
ToMang07's Avatar
ToMang07
The problem with owner's manuals these days, especially truck manuals, is that they apply to many other vehicles besides the one you bought.
With the amount of options and features available on each of six plus trim levels, it's hard to determine if what the manual says applies to your vehicle, "if equipped".
You're not making any points.
All hubs on the Ford pickups are either auto (vacuum) or lock (in case of vacuum failure) Anything else is aftermarket. Been that way since Ford came out with the Super Duty.
Old Jun 26, 2023 | 03:58 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Manual T-case and Free/Lock hubs were an option through 2019. 2020 trucks did away with the manual options, and it's all Auto/Lock since then.
There is a very simple wiring modification one can make to their new trucks that keep the hubs from engaging when in Auto mode. Yes, my Auto/Lock truck is easily capable of 2WD-low range now.
Old Jun 26, 2023 | 03:59 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Incorrect.
Old Jun 26, 2023 | 04:09 PM
Mick83's Avatar
Mick83
Oh, brother.
Old Jun 26, 2023 | 05:27 PM
Sport45's Avatar
Sport45
If you unplug and cap the vacuum supply to the hub solenoid the "Auto" hub will work just like the old "Free" hubs.
Old Jun 27, 2023 | 06:25 AM
HeavyAssault's Avatar
HeavyAssault
I'd give the "other" option to the 2wd mod (4wd mod/whatever it's called) is to use the ELD (electronic locking differential) that's found on the newer models. I can't tell you how many time I just hit the ELD and get the traction I needed. Way better in my mind than "needing" to mod a harness.
If you don't like the ESOF hubs/system then you do you. The aftermarket hubs are not any better than OEM since Warn makes the OEM hubs as well. Ever wonder why there's NOT a "better" ESOF style hub??
ESOF hubs need to have some movement to engage properly. If you are on of those types that get stuck THEN try to use ESOF you are not using the system properly. You will need to turn the ESOF hub to Lock when completely stuck, unable to move. IF you are a person that knows better, you use ESOF before getting stuck.
I played around plenty with the ESOF hubs on my 2006. I learned a lot, asked questions, in a way understand the ESOF operation.
Use what you want: Good old turn style Free/Lock hubs. ESOF Auto/Lock hubs. They do the same thing.
Old Jun 27, 2023 | 02:55 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I think you are confused on the 2-low mod. It’s not about traction, it’s about using the gear reduction of low range to your advantage for certain situations. The best use is for maneuvering heavy trailers around on hard surfaces like asphalt, where the binding of 4wd could break things. Backing a 5th wheel in from the street to someone’s side yard, or maneuvering one around the campground, etc. I use it backing my equipment trailer up my driveway.
And by “modding the harness”…it’s literally snipping one wire and hooking a relay or toggle switch inline. One butt connector and a piece of heat shrink and you’re back to factory.
Old Jun 27, 2023 | 04:22 PM
HeavyAssault
There's always someone else who doesn't want to cut the harness, nor do they "need" 2Lo. They just want a tad more traction since they are slipping on wet grass.
Old Jun 27, 2023 | 04:46 PM
  #28
RidgwaySD's Avatar
RidgwaySD
There is always that someone who has it all figured out for the rest of us... Despite a bunch of rhetoric that shows they don't need or use 4wd much.
Old Jun 28, 2023 | 05:04 AM
  #29
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
True, but like I said, it's not about traction. In fact, the 2-Low mod works best when there is an abundance of traction.
Old Jun 28, 2023 | 05:14 AM
  #30
B-ManFX4's Avatar
B-ManFX4
Exactly !!!
I back my RV and my heavy equipment trailer up my long driveway. The 2-Low mod makes it so much easier to maneuver them to their parking spots. Helps in rougher campgrounds too. Great mod if you move heavy stuff all the time.
zlalonde
Feb 1, 2025 07:17 PM
55napco55
Feb 1, 2007 09:14 PM
Riata_Ag
Jan 18, 2007 02:55 PM
seagull369
Jun 27, 2003 10:59 AM
