Draining old DEF fluid?
Old Jun 24, 2023 | 04:28 PM
Nicholas Hall's Avatar
Nicholas Hall
4th Gear
Anybody need to drain their DEF fluid? Is there a way to disconnect and somehow make the pump run using ForScan or by doing something else. Need to get out old DEF.
Old Jun 24, 2023 | 05:42 PM
4wd6.7L's Avatar
4wd6.7L
How old is this DEF and is it throwing a code?
Old Jun 24, 2023 | 06:56 PM
Nicholas Hall
4th Gear
No, but it’s been sitting with 1/3 tank for a long time. I don’t drive much and know it gets old and causes issues
Old Jun 24, 2023 | 07:16 PM
4wd6.7L's Avatar
4wd6.7L
How long is a long time?
I'm sure it's fine. Unless it throws a code there is no reason to worry about it. Doesn't matter if it's 1/3, 3/4, or full, it actually lasts quite awhile. In my 2019, because of how few miles I put on the truck (approx 4k/yr), I only add one 2.5g jug in per year. I wait till it shows 1/4 and then add the 2.5g which then shows 5/8 on the gauge. Haven't had a problem yet.
If dead set on removing the DEF, siphoning seems to be the suggested method based on other threads.
Old Jun 24, 2023 | 07:25 PM
fordman19762003's Avatar
fordman19762003
DEF lasts longer than a guy thinks. I asked a pretty good heavy diesel mechanic and he said the thing that kills DEF the fastest is exposure to sunlight and extreme heat. Unless the DEF was a couple years old I'd just add fresh to the tank and run it.
Old Jun 25, 2023 | 06:07 AM
senix's Avatar
senix
I would not touch it. Rather go tow something and that will burn the def quickly.
Fred Heisel
Oct 29, 2020 05:43 PM
F0rdE$cape
Escape & Escape Hybrid
Apr 21, 2014 05:01 AM
fairview1
Dec 31, 2012 10:53 PM
shorthair
Mar 5, 2008 11:28 AM
teddyu
1983 - 2012 Ranger & B-Series
52
Jul 31, 2006 07:07 PM
