Limited Alternators
Old Jun 23, 2023 | 09:14 AM
redford's Avatar
redford
FTE Leadership Emeritus
My understanding of the 2019 MY was that the 332 Amp option was a single alternator. The 397 Amp option was dual alternators. Regardless of trim level, you only got dual alternators on the 6.7L PSD if you ordered the rapid heat option, the snowplow prep option, or specifically optioned dual alternators.
Old Jun 23, 2023 | 09:15 AM
19Limited's Avatar
19Limited
8th Gear
Yes, but I take it that your truck is a Lariat and all that stuff are options on your truck. On my Limited the diesel engine and alternators are supposed to be standard. The only thing that would be an option is the rapid heat.
Old Jun 23, 2023 | 09:21 AM
redford's Avatar
redford
My understanding is opposite. Dual alternators were not automatically included for the Limited trim level for MY 2019.
Your truck seems to support that.
My truck has dual alternators, but it is because of the snowplow prep option, not the Lariat trim level.
Old Jun 23, 2023 | 09:36 AM
shawnee1's Avatar
shawnee1
Assuming the alternator listing in post #5 is accurate, it does show that dual alternators (332 amps) are standard for Limited trim and dual alternators (377 amps) on Limited's with supplemental heat.
Old Jun 23, 2023 | 09:39 AM
HRTKD's Avatar
HRTKD
It wouldn't be the first time that Ford's documentation was wrong.
Old Jun 23, 2023 | 09:44 AM
BEBosworth's Avatar
BEBosworth
Originally Posted by 4wd6.7L
Limited (and 450 pickup) is available with 6.7l only.
Having never owned either, I was not aware of that. Makes sense I guess. Do the 7.3 guys know this?
Uh-oh
Old Jun 23, 2023 | 09:46 AM
redford's Avatar
redford
Exactly.
Post #4 shows the 332 Amp option as a single alternator.
Old Jun 23, 2023 | 10:45 AM
shawnee1's Avatar
shawnee1
Exactly.
It has been common for Ford to use the singular "alternator" instead of the plural in their documents for dual alternator systems. I would not assume a single alternator just because there is no "s' at the end. I don't know if they even make a single alternator with 332 amp output as other references describe that output as dual.
Old Jun 23, 2023 | 10:49 AM
redford's Avatar
redford
The second attachment from Post #5 would indicate otherwise.
Old Jun 23, 2023 | 10:50 AM
19Limited's Avatar
19Limited
8th Gear
Sorry, I was actually replying to HRTKD
Old Jun 23, 2023 | 11:00 AM
19Limited's Avatar
19Limited
8th Gear
I looked up the part number for the single alternator that is on my truck and it is the 220 amp alternator. Which would be the 67D option.
I don't know guys. Everything says that all Limiteds came standard with the 332 amp duals. I have seen other posts that also mentioned that the 332 amp was a single alternator but have not seen anybody prove it. And I have not seen anyone else with a Limited say that they also only had only one alternator. I would feel better if someone else said that they also have the single but I seem to be the only one.
Old Jun 23, 2023 | 11:02 AM
shawnee1's Avatar
shawnee1
I'm not sure that it does. The last line item in post 5 for order code 67B uses the singular form of alternator for the dual. When I wrote "common", I did not mean all the time but enough times that it not a reliable way to differentiate.
dustyroad
Oct 15, 2019 10:49 PM
Nytefog
6.7L Power Stroke Diesel
Apr 25, 2015 08:20 PM
Subzero68
Dec 19, 2013 09:40 PM
freef2504x4
Jan 23, 2011 11:58 AM
Customz
Dec 27, 2004 10:36 AM
