Idles low on Warm engine
Old Jul 4, 2023 | 04:12 PM
FuzzFace2's Avatar
FuzzFace2
What is "point gap .017 (ignored the fuel tank emissions)" did you mean plug gap and ignore?
If so then it is too small as it should be think .34 or so.
Bump the timing up to 10 to 12 BTDC
That should bring the vacuum up some as 17 is a little low for a stock motor in good shape.
If you found and fixed the vacuum leak you will need to readjust the carb mixture screws.
What is the idle speed in gear?
Dave ----
Old Jul 8, 2023 | 04:56 PM
sevenoneranger's Avatar
sevenoneranger
It states everywhere to set the point gap in the dist. to .017, or if the fuel tank has emissions to .021. But everyone here states .017, so I ignored the emission tank setup. The timing was bumped around 7 degrees to 10.. it ran better at the lower numbers.
As of right now when the truck is first warmed up the idle is around 750-800. But after the engine runs for awhile and gets hot, the idle drops to 650ish. My problem now is figuring out why the idle drops after the engine is hot. It seems to continue to decrease in idle and when put into gear, has time of stall out.
I have yet to swap the valve cover gaskets, but I don't feel that is the issue here.
Old Jul 8, 2023 | 09:09 PM
RTT's Avatar
RTT
You may have a vacuum leak , or vacuum advance diaphragm may be going out or have a crack . Things expand when warm & hot.......... Electrical , rubber , metal..........my mouth
bertolina
19
Jan 1, 2015 09:22 AM
bob8492
Feb 27, 2014 08:33 AM
bttf
17
Apr 19, 2013 05:29 PM
Iron Horseman
May 21, 2006 11:01 PM
Baby-Semi
Dec 21, 2004 01:51 PM
