Anyone know what to do from here?
Old Jun 20, 2023 | 12:28 AM
Phirrup's Avatar
Phirrup
4wd High
Latch for tailgate step broke off
A new assembly is 1200 from Ford and about 700 used off eBay. Anyone know an easier way to fix this?
Old Jun 20, 2023 | 04:04 AM
ToMang07's Avatar
ToMang07
What/where is that from?
Old Jun 20, 2023 | 04:11 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Looks like it was held on with a rivet, and the rivet broke? If so, put it back on. Either with another rivet or with a small bolt. You may have to disassemble the tailgate to get to its home though...
Old Jun 20, 2023 | 05:04 AM
Phirrup's Avatar
Phirrup
4wd High
The tailgate step that pulls out of the top of the cap
Old Jun 20, 2023 | 05:10 AM
B-ManFX4's Avatar
B-ManFX4
Use a vise or an arbor press to straighten the metal latch, install a new rivet or a suitable bolt / fastener and, most of all, tell whomever is abusing the step to stop doing it.
Old Jun 20, 2023 | 06:24 AM
ToMang07's Avatar
ToMang07
Didn't narrow it down much. Was that for the step release button?
If you can get to wherever it came from, I would think it shouldn't be too difficult to straighten it out and rivet it back into place. Or replace with stainless hardware.
Old Jun 20, 2023 | 07:29 AM
scraprat's Avatar
scraprat
Top Answer: 5
The red arrow points to the rivet that was there. Small nut and bolt would take of it possibly but not tight. There is a spring connected to it. Undo the 2 t30 bolts might help with repair. Doesn't look that difficult and much cheaper than $700 - $1200.
Fyi this is how to adjust the latching of the step with 2 t30 bolts. Loosening them in or out of the whole mechanism.
Old Jun 20, 2023 | 02:13 PM
Phirrup's Avatar
Phirrup
4wd High
I'll dig in to it later tonight, thank you!
Old Jun 20, 2023 | 06:11 PM
Bruce M.'s Avatar
Bruce M.
I agree with the nut and bolt but this is a pivot point and it needs to be somewhat loose, I would put a SS washer on each side and use a nut with the nylon locking in the top end of it. This will stop it from falling g out every 10 times you use it.
daletodd2
Dec 26, 2019 08:25 AM
Don52M3
Apr 21, 2019 02:34 PM
1986F150six
Mar 31, 2017 09:34 AM
drbalazo
Apr 25, 2008 04:42 AM
Fraalan
Jan 18, 2008 10:11 AM
