valve body question
Old Jun 22, 2023 | 05:06 PM
  #46
uglypitbull's Avatar
uglypitbull
Originally Posted by Mark Kovalsky
I have no idea what they know and what they don't know. I know that when I was creating stock tunes I knew what PSI I was calling for. I had pressure sensors installed in the trans and with the installed instrumentation, I knew what pressures were in each clutch.
There is a safe limit and the pump can't exceed that. It doesn't have the capacity.
This is exactly what I needed to know......
Just FYI...Andrew has already reached out to me.....fingers crossed
Old Jun 22, 2023 | 05:35 PM
  #47
jstihl's Avatar
jstihl
I think you will be happy with his tunes, I only had to get a couple revisions to get the trucks dialed in. Have been very happy with them
Old Jun 23, 2023 | 12:51 AM
  #48
uglypitbull
Looks like it will be Friday before I hear back from Andrew again.
Matt at GH reached out....said to put the Hydra in stock (00) setting and see if it shifts any different....I guess it will idle like crap but should drive fine and not hurt anything.
Old Jun 23, 2023 | 09:06 AM
  #49
RacinJasonWV's Avatar
RacinJasonWV
Remember, to go into bypass mode you need to do this with engine off then key off for it to take effect.
Old Jun 23, 2023 | 11:05 AM
  #50
uglypitbull
Andrew just sent over a few to try out.....I'll test out the stock setting just to rule out the transmission.
Would a transgo kit make it shift soft? I got an email back from the transmission shop.
"We have had pretty good success using these aftermarket upgrades on this unit. Like with anything though with tuners gone wild - things will break.
It is a Transgo shift kit, I believe the feed seals, reverse plunger, and line pressure sleeve are all Sonnax.
The HD center support is a must on these units along with the HD int sprag.
The converter has a billet lid and they machine the stator for better take off for towing. "
Old Jun 23, 2023 | 05:23 PM
  #51
uglypitbull
Called Transgo and they mentioned there was no mechanical reason why shifts couldn't be tuned for firmness.
Then I loaded up a couple of the AA tunes from Andrew......and HOLY CRAP!! @jstihl and @ESwift you guys were both right about this decision.....freakin nailed it!!
Are your tunes pretty smoky if you get on it? These initially blew a big black plume but cleared up almost immediately. Just wondering if that initial fuel dump could be tapered a bit up front....but wow! I am a believer.
Thanks for that recommendation! My wife just told me I am still wearing the grin.
Old Jun 23, 2023 | 05:34 PM
  #52
ESwift's Avatar
ESwift
CNCFAB
Good to hear!
AA can tweak that tip in smoke out with zero issue
F250_HD_Crew
Aug 7, 2012 07:17 PM
7.3blacksmoke
Jan 15, 2009 04:52 PM
midnight1967
Mar 30, 2008 09:48 AM
JoeTrotter
Aug 17, 2007 04:41 PM
4X4 IN REFUGIO
Jan 16, 2007 08:18 AM
