2019 F250 Brake controller
Old Jun 17, 2023 | 07:12 AM
Heath-n's Avatar
Heath-n
2nd Gear
Bought a '19 F250, did not have a brake controller. I want the OEM one but am being told it is not compatible with my vin. I have the cutout in the dash and the pigtail is behind it. What does this mean?
Old Jun 18, 2023 | 11:33 AM
HarveyTruck's Avatar
HarveyTruck
What trim is the truck? Unless it’s super bare bones XL it probably had it originally. I thought all the newer SDs came with it standard. If it didn’t then the VIN might show that. They dealer parts departments always want to use your VIN to order stuff, doesn’t mean you can’t add or change things just have to order them independently or use a VIN from something else.
Should be plug and play. I added one to a ‘15 F-150 that didn’t come with it. Bought it from the parts counter and had the dealer install it when I bought the truck new. They charged me 30 minutes to install it and program it to the truck. That truck did have tow package but no controller.
Old Jun 18, 2023 | 11:46 AM
1olddogtwo's Avatar
1olddogtwo
That is partially correct, they are plug and play in a sense, currently your truck (that VIN/ECM) will not recognize it. It could be done with froescan or a trip to dealer.
Old Jun 18, 2023 | 11:56 AM
minke's Avatar
minke
My '17 xl was on the lot without a controller. One of my conditions for purchase was that the dealer install the factory controller. They were motivated.
I suspect that they can for '19s too.
Old Jun 18, 2023 | 12:50 PM
Heath-n's Avatar
Heath-n
2nd Gear
Yes it's an XL, single cab 2wd, ect. Does have factory looking hitch.
Talking with a guy on another forum, the base trucks may not have the pressure sensor to run the factory controller.
Old Jun 18, 2023 | 01:06 PM
4wd6.7L's Avatar
4wd6.7L
This looks base to me and mostly a plug n play procedure. I bet Forscan would do it instead of IDS.
Old Jun 19, 2023 | 07:46 AM
B-ManFX4's Avatar
B-ManFX4
There are two addresses in the IPC module that FORSCAN can access to enable the TBC. These are the settings from the F-150:
Trailer Brake Control Module Enabled: IPC 720-07-01 xxxx x*xx xxxx If your as-built is 0, use 8. if your as-built is 6, use E
Trailer Brake Controller Gain Setting Enabled: IPC 720-04-01 xx4x xxxx xxxx
Note the F-150 does not appear to have a separate TBC module at address 757 like the Super Duty does. Might be worth a message to ZooDad to see if he has any info.
Enginetech88
Jul 30, 2022 11:45 PM
silentrunning
Sep 1, 2011 04:50 AM
partsman01
All Things Towing
Jul 15, 2005 06:57 PM
