Help with broken valve assembly?
Old Jun 11, 2023 | 03:19 PM
52F1NM's Avatar
52F1NM
2nd Gear
I am working on my flathead V8 from a 1952 Ford F1 pickup. The engine was locked up and I was able to get it freed, but one of the exhaust valves was getting stuck open. After taking off the intake manifold, I found that one of the exhaust assemblies was broken. Pictured below:
I was about to just order a replacement from LMC but then I read on this post: "https://www.ford-trucks.com/forums/1670906-difference-between-exhaust-and-intake-valves.html" that there are two distinct types of valve assembly, rotomatic and non rotomatic. I believe that my assembly appears to be the rotomatic variety, but none of the replacement valves that I have found online are advertised as rotomatic. Can anyone direct me a seller that has this type of assembly? Or is there anything else that I am missing?
Old Jun 13, 2023 | 10:46 AM
f5fordgirl's Avatar
f5fordgirl
I've looked at those pic's a dozen times, and have not yet found what you're calling broken.
Old Jun 14, 2023 | 03:49 PM
52F1NM's Avatar
52F1NM
2nd Gear
I believe it is called a retainer sleeve, but I have seen it called different things.
Here is a close up:
I believe it is part 6517 in this diagram: "http://www.vanpeltsales.com/FH_web/FH_images/FH_engine-pics/Flathead_Engine_valve1949to53.jpg"
Old Jun 20, 2023 | 04:28 PM
33ratrod's Avatar
33ratrod
It looks like your missing the two retainer clips off the top of the valve. Looks like they go down inside the bent piece your showing not sure where you buy that.
Old51f3
May 7, 2019 05:38 AM
Gary Lewis
33
Mar 9, 2016 09:13 PM
raven3
18
Jul 24, 2014 03:24 AM
MercM47
Jul 15, 2004 07:35 PM
MercM47
Oct 24, 2003 11:57 AM
