17 brake caliper bracket
Old Jun 11, 2023 | 02:43 PM
Gwilkrrs's Avatar
Gwilkrrs
So 1 slide froze and broke off in the bracket- odd since all other slides were free……….
anyone know if I have to go back to the dealer for a front caliper bracket? I only see the caliper and bracket being sold-
thanks
Old Jun 11, 2023 | 03:28 PM
morehouse7's Avatar
morehouse7
thanks
Rock Auto has them
Old Jun 11, 2023 | 05:46 PM
Gwilkrrs's Avatar
Gwilkrrs
Thanks,
I could only find the rears- I will look there
Old Jun 11, 2023 | 06:07 PM
scraprat's Avatar
scraprat
Top Answer: 5
thanks
When was the last time they were taken off, cleaned the sliders and regreased them? The pistons on that caliper operating properly?
Old Jun 12, 2023 | 05:16 AM
Gwilkrrs's Avatar
Gwilkrrs
well i asume the piston is working on the caliper- they retracted back.....
the last brake check i pulled the pins and lubed them.
only 1 pin out of 8 was bad- all other pins were still greased and sliding, this pin was rusted solid and when i tried to free it sheared off
Old Jun 13, 2023 | 06:14 PM
BOSS 379's Avatar
BOSS 379
Better luck than I had on my 19 today… only did the rears and 3 out of 4 were seized, causing a pad squeak.
Old Jun 14, 2023 | 05:14 AM
Gwilkrrs's Avatar
Gwilkrrs
oooof- sorry to hear that-
Old Jun 14, 2023 | 10:42 AM
BOSS 379's Avatar
BOSS 379
Thanks; guess I’m part of the club now. It took some elbow grease, but they are cleaned up and lubed again. I’m not sure why at 40k miles three were seized and one wasn’t; dust boots weren’t torn on any of them. Thanks to this thread I know where to source some spares.
Old Jun 14, 2023 | 12:09 PM
scraprat's Avatar
scraprat
Top Answer: 5
Slide pins are one of those things that many assume they're are lubed enough and besides they have a rubber boot on them for "protection". After the first time dealing with a frozen pin on my "88" 30 years ago I make it part of my preventive maintenance when first getting a truck and pull the sliders out, clean them and give new lube. Pick your poison for flavor many out there.
It's easier than dealing a frozen slider and other parts.
Old Jun 14, 2023 | 09:11 PM
aklim's Avatar
aklim
Just as you won't change the filter without changing the oil, why not the caliper too? Think of it this way. What do people do when changing pads? Squeeze the caliper in, slide in new pads and go with that. My procedure for it was partially from shop class. I was told to open the bleeder screw and push the pads in and then burp it. Why? The caliper is the lowest point and crud settles. So why push it back into the system? I do flush the system ever 2 years and open the bleeder when installing new pads. I also take the slide pins out, toss the boots and spray brake cleaner into the bores to get all the old grease out and clean the pins. After which, I reinstall with fresh grease and new boots and finish the job. Grease gets old and might not do it's job as well.
Old Jun 26, 2023 | 07:45 AM
Great Danes's Avatar
Great Danes
So my question to all of you is, what do you use to lube the pins? My truck is just under 3 yrs old with 57,000kms. I do a brake service every 6-8 months that includes pulling the pins and lubing them with silicone brake lube which has kept them moving freely....until yesterday. I have one stuck pin on each of 3 brackets. One of the pins on the fourth bracket was a bit stiff to remove. Thankfully, I still have warranty and this will be covered, but I don't want this to happen again in the future when I am on the hook for costs.
Any thoughts on lube or I suppose I will shorten the service interval to 4 months.
Old Jun 26, 2023 | 09:02 AM
scraprat's Avatar
scraprat
Top Answer: 5
I've used this on all my trucks slide pins and never had one freeze up.
Edit: When I first get new trucks after first oil change (5-7k miles) I'll go through and wipe off any old grease from slide pins, put a few lines of the new grease in pic on pins. Put pins back in caliper and spin the pins along with moving them in and out to disperse the grease on the entire pin/ bore. Put some in the rubber boots. The pins won't be touched again till brake pads need replacing usually around 50-100k or 1.5-2 years. Redo when doing brake pads in another 1.5 -2 years. I've done this on my past 5 trucks with each having 200-300k miles and never have had a frozen pin.
Old Jun 26, 2023 | 09:09 AM
aklim's Avatar
aklim
Do you just use fresh lube or clean out the old stuff first?
Old Jun 26, 2023 | 10:33 AM
Great Danes
I clean off the pin and clean out the barrel as much as possible before applying new lube.
Old Jun 26, 2023 | 10:36 AM
aklim's Avatar
aklim
I flush the bore with brake cleaner and wipe off the pin and usually toss the boot for a new one every time I do a brake job.
