In Dash Digital Readout
Old Jun 10, 2023 | 11:05 PM
KenRebF-250's Avatar
KenRebF-250
About a month ago we purchased a 2021 F-350 SD STX, 7.3 gas. I've been told there is a real time digital gauge that shows transmission temp. I haven't been able to access that readout. A Ford dealer tech, without seeing the truck, said it may not have the trans. temp readout capability. He went through the different modes with me over the phone and we were never able to access the info I seek. He wasn't 100% sure it isn't available so I thought I'd see if anyone here might know for sure.
TIA.
Old Jun 10, 2023 | 11:39 PM
4wheelsandahitch's Avatar
4wheelsandahitch
My 21 XLT displays the transmission temperature. You do have to scroll through screens.
Old Jun 11, 2023 | 01:37 AM
KU4OJ's Avatar
KU4OJ
On my truck, see sig file, I go to the screen with the tire pressure and oil life monitor, then use the up/down cursor controls to try to go up or down "further than the selections on the screen will allow" if you get my thought here. Then the transmission temp selection will appear, along with elapsed time on engine hours.
From memory, but something like that.
Old Jun 11, 2023 | 09:40 AM
KenRebF-250
Okay, I'm not following some of your semantics, ie "sig file" and "further than the selections on the screen will allow". If possible please expand on this.
TIA.
Old Jun 11, 2023 | 11:24 AM
jimzpsd's Avatar
jimzpsd
Instead of a lengthy write up, perhaps your owners manual can guide you.
Old Jun 11, 2023 | 12:54 PM
KenRebF-250
I certainly appreciate your guidance, concern and spot on advice but, although I haven't read it page by page (it compares to War & Peace in length and word count) and word for word, I've taken the time to go through glossary and index entries and haven't run across any references yet. Maybe you could contribute something besides the obvious drivel if your the on site expert.
Just figured someone with sincere and straight forward info and advice would reply. 2 out of 3 so far have attempted to be of assistance. I reckon that isn't too bad of an average.
Old Jun 11, 2023 | 01:33 PM
mwheue's Avatar
mwheue
Press the left arrow two or three times, scroll up or down to drivers assist and press ok, then scroll up and or down to look for Trans temp. If it's there select it and hit ok. May or May not be available? My manual says oil temp is selectable also but it is not.....
Old Jun 11, 2023 | 01:41 PM
KenRebF-250
Thank you kindly, sir. I will give your method a try. The salesman at the Ford dealer where I purchased the truck was uncertain as to whether or not the information center has the trans. temp capability and no one else at the dealership knew for sure, either. Given that I come up empty by checking out the operator's manual our truck may not have the capability.
Thanks again.
Old Jun 14, 2023 | 07:23 PM
KU4OJ's Avatar
KU4OJ
TIA.
OK, first off a "sig file" is a signature file, or that verbiage at the bottom of your post. You have one, I have one.
Now, how to find the temp gauge. On my truck, as described below, I have the 4.2 inch info screen between the tach and speedometer so my instructions assume you have the same. Go to the top of the menu, top screen. Select display options, which should then display "oil life monitor" and "tire pressure monitor." From this screen keep pushing the up arrow and more options will appear (if not, use the down arrow).
On my truck, this will now show tire pressure, oil life monitor, transmission temp, engine hours and a couple more I can't remember. It's just a little bug in the code that drives the menu system on that screen. The transmission temp gauge is real time, digital and takes up the entire 4.2" screen.
Let us know if you find it (or not)
Old Jun 15, 2023 | 08:13 PM
KenRebF-250
Thanks a ton for the helpful response! You are spot on!!
As I said above, I scoured the owners manual and either overlooked the info or it isn't included, which is a mute point either way.
Thank you again, sir!!
Flitastic
Jun 5, 2023 03:34 PM
senix
6.7L Power Stroke Diesel
29
Nov 26, 2013 12:06 AM
DikHedECV3
Feb 12, 2013 06:20 PM
hdman6
Apr 22, 2012 03:33 PM
eric3t
1978 - 1996 Big Bronco
Aug 19, 2002 09:14 PM
