91 F 150 w 5.0
When Hz testing my map sensor getting Hz reading without even grounding out the other probe of my meter. The numbers are pretty much correct according to the scale, only 2 Hz off when throughout atmosphere, 5"hg, 10"hg, 15"hg, 20" hg.. what does this mean?
I'm actually kind of impressed that you would go to the trouble of checking that. I had to search for what sort of results you may find and I found this. https://f01.justanswer.com/nmwagscha...nge_charts.pdf
Now, given that the frequency range is something like 80 to 150 hz, I don't think a 2 hz error would be significant. As to why you get a reading with only 1 lead connected, that may depend on your measuring equipment. A hi Z input with lots of sensitivity may show a reading with the return disconnected, but I would certainly question accuracy till you had a hookup within the design of your equipment. Since we don't know what you are measuring with, any guess we make will be pretty much useless.
Something isn't letting me attach a picture of the meter. It is an IDEAL meter from Lowes, has numbers 61-737. I have other meters but none read Hz. I had to use other meters to resistance test/ ohm out some sensors because I realized this one isn't working on ohm function, not sure if that has anything to do with the Hz capability but wouldn't surprise me. I probably messed it up by accidentally sending voltages through it while on ohm setting. Anyway, here is an update to my truck, also on another thread.
So far have replaced EGR control solenoid, iac valve, TPS sensor, map, O2. Just took it for a short test drive and I think new sensors made my check engine light stay off, also realized the high idle has gone down when I put it in gear.Does anyone understand why the truck will idle high in park but go down to normal when in gear?
That's a pretty decent DVOM/clamp on ammeter. Likely designed more for the electrician than for automotive work, but it would be pretty hard to hurt that instrument with the voltages found in your truck.
Now, what I don't know from this post is that you have another post going where you discuss all the diagnosis you have already done. Just to help everyone out a bit, probably best to continue the discussion there.
