Speedometer/Tach Calibration
Old Nov 18, 2003 | 02:55 PM
Trailhiker's Avatar
Trailhiker
Question Speedometer/Tach Calibration
I recently purchased a 2001 Ranger 4x4 XLT that the previous owner had installed a blue/green EL face instrument panel overlay.
Obviously, to install it, he had to remove the tach and speedometer needles.
I'm not sure if they were reattached properly, to give the correct readings for each one.
Does anyone know what the procedure to reattach the needles to the gauges are (so that the gauges are accurate), or if they work with whatever sensors they are attached to give an accurate reading.
TIA
Old Nov 18, 2003 | 08:38 PM
wolfen's Avatar
wolfen
Welcome to FTE Trailhiker,
He removed the needles, (or is there something here that I'm missing)? Not familiar with this problem!
Anyway:
Set both needles @ -0- <zero.
This should do it, I would think!
Old Nov 18, 2003 | 09:14 PM
WXboy's Avatar
WXboy
You can go out on the interstate highway with a stopwatch. Set the cruise control where your needle is reading exactly 60 miles per hour. Time how long it takes between mile posts. Should be 60 seconds between each milepost. Do this for a few miles to be sure.
That will tell you if your speedo is inaccurate and how much it's off.
Old Nov 19, 2003 | 04:46 AM
Trailhiker's Avatar
Trailhiker
Wolfen -
In order to put the overlay on top of the speedometer/tach portion of the instrument panel the needles had to come off. On the other sides (gas & temp and oil & battery) one could slip the overlay under the needles, but because the needles for the speedometer and tach are so long, one would have to remove them to place the overla on the faceplate.
Thanks, all, for the thoughts!
captain1997
1997 - 2003 F150
Nov 27, 2015 11:01 AM
crystalhand
Oct 18, 2015 09:27 PM
Steve
16
Aug 30, 2015 04:54 PM
Macs1964F100
13
Jul 11, 2014 11:21 AM
Special_edward
20
Jan 6, 2008 08:31 AM
