TTB Inner u-joint passenger side
Old Jun 8, 2023 | 12:10 AM
seagull369's Avatar
seagull369
I wanted to change the inner u-joint on the passenger side and was wondering if it's possible to do it with the inner shaft still connected up in there to the diff, This would be using the usual big c-clamp type tool. I'd love to pull the shaft and work on it on the bench, but I'm figuring disconnecting it from the diff isn't a simple affair.
Anyone have some suggestions?
Old Jun 8, 2023 | 11:22 AM
Black3's Avatar
Black3
4wd High
Easy peasy
Mine was simple to remove. Slid right out. Gotta remove the gingerbread on the outer axle then the boot, but yea, no clip inside the differential.
Old Jun 8, 2023 | 12:45 PM
seagull369's Avatar
seagull369
Thanks for the reply. Could you clarify what you meant there? I'm not following.
Old Jun 8, 2023 | 07:27 PM
Black3's Avatar
Black3
4wd High
The wheel, 4x4 hub, the spindle hub. The boot that covers the ujoint, then it slid right out. It's retained into position by the wheel bearing nuts and outer C clip.
Old Jun 8, 2023 | 11:31 PM
seagull369's Avatar
seagull369
I cut the pinch clamp on the rubber boot and slid out the outer shaft, but the inner is locked into the carrier. When I push and pull on it, it moves slightly giving the feeling either there's a spring clip holding it in place (like a cv joint would have) or there's an internal c-clip inside the axle that needs to be removed 1st (like the rear axle has).
Old Jun 9, 2023 | 12:03 AM
seagull369's Avatar
seagull369
Came across this video:
This seems to be a Dana 28, but I'm wondering if the 35 works the same. Anyway, according to the guy, the diff needs to be dropped and clip removed internally (he shows it @ ~3:35) then that inner passenger side shaft can be removed. .
Old Jun 9, 2023 | 12:30 PM
Black3's Avatar
Black3
4wd High
Dana 35
o
OK so I remember mine is a Dana35. Is your front diff/axles the same?
Old Jun 9, 2023 | 01:43 PM
seagull369's Avatar
seagull369
Not sure what you mean there.
I did more digging and pretty much confirmed there is an internal clip that holds that shaft in. The diff needs to be dropped to get it out. Perhaps something unique was going on with yours', Black3, that made you able to just slide it out without having to do that.
Thanks again for the help.
Old Jun 9, 2023 | 10:15 PM
Black3's Avatar
Black3
4wd High
Is yours the Dana 35? Curious
Old Jun 10, 2023 | 12:14 AM
seagull369's Avatar
seagull369
Yes, Dana 35.
Jul 29, 2019 12:05 PM
AVR2
Escape & Escape Hybrid
Apr 3, 2017 11:46 AM
wickedklown83
Oct 11, 2010 11:14 AM
mattdmason
13
Dec 31, 2009 02:51 PM
71 Muddbugg
Apr 10, 2005 07:20 PM
