stereo draining battery
Old Jun 8, 2023 | 09:05 AM
toolman60's Avatar
toolman60
The yellow with Black trace wire in your truck harness connector c333 should be the switch wire = On in ACC,ON position of the key. And it should connect to the RED wire on the head unit.
Old Jun 8, 2023 | 10:17 AM
mackendw's Avatar
mackendw
The Yellow with Black trace wire is on the truck side of the plug however, it doesn't come out as Yellow/Black on the stereo side so I don't know which one to use...
I can live with it working ONLY in the ON position on the key...at least now it is shutting down with the key off.
Old Jun 8, 2023 | 10:27 AM
toolman60's Avatar
toolman60
look at the wire harness between truck connector and the radio. You should be able to follow the wire.
Old Jun 9, 2023 | 09:24 AM
mackendw's Avatar
mackendw
truck fired right up after sitting all night with the stereo connected (powered off)...so it would appear that this was my source of the drain.
all good.
Pjuhl2313
33
Oct 4, 2022 02:31 PM
Jazzguy
Nov 4, 2020 06:12 AM
GABAR
2015 - 2020 F150
Aug 12, 2020 09:18 PM
Woody1255
Aug 4, 2009 05:59 AM
maddhatteraz
Electrical Systems/Wiring
Dec 4, 2007 01:52 PM
