Drivers side window Control and mirror Control
Old Jun 7, 2023 | 01:41 PM
RicManSr's Avatar
RicManSr
Just bought a 2019 F250 4x4 Lariat, and the driver's side control for the driver's window, and the mirrors are not working. Both rear windows on that control wok, but not the front windows. I've changed out the door switch with a known good one and it didn't help. I've checked the fuse (#23) passenger side footwell, and its good also. I have a 2000-mile road trip to take tonight pulling a trailer and need to be able to adjust my mirrors. Is there anything else i can check/fix to get this working? The dealership is no help until next week. Is this a known problem, and can it be remedied at home instead of the dealer?
Thanks
Ricky
Old Jun 7, 2023 | 06:28 PM
RicManSr's Avatar
RicManSr
Nobody ever heard of, or had this issue before?
Old Jun 7, 2023 | 06:31 PM
BC2019F250's Avatar
BC2019F250
I would check the wires that go into the door. You can make adjustments without using the controls if you have to.
Old Jun 8, 2023 | 08:47 AM
HeavyAssault's Avatar
HeavyAssault
Since it wasn't addressed:
Do you know how to use a multi-meter?? Checking for continuity is a easy way to see what's going on with the wiring. The hard part is going to be finding the correct wires.
Not to mention if you try to take the door apart to see if the switches are sending the signals to the motors for the windows. Same with the door mirrors. You need to have an assistant or at least three sets of additional arms/hands. LOL
Old Apr 4, 2025 | 03:57 PM
Israelp's Avatar
Israelp
3rd Gear
Yo tengo el mismo problema. ¿Pudiste solucionar el problema?
Anthony Giovino
Apr 4, 2025 03:47 PM
Jtegg007
Dec 30, 2022 09:27 PM
edjunior
Sep 5, 2022 11:18 PM
Dozier
2004 - 2008 F150
Jun 27, 2014 11:28 AM
nymo
Jun 18, 2007 10:58 PM
