Killing PCM memories
I've read in several places that you should disconnect the battery to kill the memory in the PCM (ECM?) when replacing the ICM, ICV, or other parts and sensors. This apparently allows the computer to "re-learn" its parameters for engine management with the new parts.
Does it really work this way? Seems the computer would always be learning and mapping due to changing conditions anyway. A new part, like an O2 sensor, would just be woven into the solution.
Thoughts?
Thoughts?
There are at least two, and most likely 3 processor fuses on whatever he's driving
It is the KAM processor feed fuse that needs to be pulled
They always told us in Screwell to use the scan tool to clear codes
Forcing the ECM to do a bunch of re learns is not detrimental but not good for it either IMO
Medic 66
26
Jan 18, 2006 10:03 PM
danielharr79
1983 - 2012 Ranger & B-Series
May 14, 2005 11:03 PM
Mr Personality
Jul 18, 2003 12:25 AM
bgodkin
Jan 31, 2001 10:22 AM
