1978 - 1996 Big Bronco
loud knock
Old Nov 18, 2003 | 12:54 PM
fordman_in_nv's Avatar
fordman_in_nv
Angry loud knock
I need some advice. My 88 bronco has a real bad knock and I cant figure it out. I replaced the mains and that wasn't it. I thought it might be the tourqe converter, allthough it did need to be replaced that wasnt it. What can make a knock like this it only knocks when I rev it up or put it in gear. Can a bad smog pump cause any thing like this? the day it first happened the end of my cat was clogged (no muffler right out of the cat) with a big piece of the honey comb stuff. what could that have done? sorry about the length, any thing would help
Old Nov 18, 2003 | 01:43 PM
BillyBob69's Avatar
BillyBob69
If it onlu does it under load then I would begin checkingfor a bent rod or excess lashing in the rocker arms.
Old Nov 18, 2003 | 02:03 PM
Hoodlum's Avatar
Hoodlum
Ok is it when. Let's say. When you are driving and all of sudden you let off the gas and you hear a knock. Because mine is doing the same thing. So if anyone knows mine let me know Too.
Old Nov 18, 2003 | 02:12 PM
BillyBob69's Avatar
BillyBob69
Hoodlum, on yours I would check to see how rich your engine is running. Yours sounds like run on knocking.
Old Nov 18, 2003 | 02:40 PM
frogger01's Avatar
frogger01
Re: loud knock
the day it first happened the end of my cat was clogged (no muffler right out of the cat) with a big piece of the honey comb stuff. what could that have done? sorry about the length, any thing would help [/B]
You said it all right there, your catalitic converter is toast. since that piece became dislodged the rest of the honeycomb is now rattling around the cat making that noise. It won't effect your motor too much but it will remain embarassing to drive around until you replace that cat.
Old Nov 18, 2003 | 03:02 PM
BillyBob69's Avatar
BillyBob69
HMMMMM see what I get for assuming. Sorry...just assumed that if there was a clog that you cleared it.
Old Nov 18, 2003 | 04:13 PM
BOJOFASO's Avatar
BOJOFASO
sounds like a bad wrist pin bushing,had this happen to me once before on my 75 f 250 highboy with a 360 .
Old Nov 18, 2003 | 10:12 PM
fordman_in_nv
the reason it was cloged was I hollowed out the cat and missed a piece. when I drove it the exhaust pussed the loose piece into the pipe causing alot of back presure. the peice was to big to blow all the way out. I'm gona go ahead and replace the cat and see if it helps plus I have to get it smoged soon anyway thanks for the help and I'll tell you if that was it
alloro
Mar 10, 2017 02:51 AM
PEG
1997 - 2003 F150
Nov 18, 2015 12:55 PM
F-ReV
Jun 9, 2014 10:45 AM
Fordx4jake
General Automotive Discussion
Oct 26, 2013 01:00 AM
rich1brad
Dec 5, 2005 10:11 PM
