New Injectors
Old Jun 4, 2023 | 10:30 AM
8lug's Avatar
8lug
New Injectors
Installing 8 new injectors.
Is there anything else I should address while I am in there?
Old Jun 5, 2023 | 10:04 AM
53jimc's Avatar
53jimc
Did this on my grandson's '05 last November.
Replaced:
Stand pipes dummy plugs and o rings
Nipple seals
​New design nipples from HHC (supposed to keep high pressure oil from destroying injector top o rings.)
If it's an '05 or later, STC fitting.
Good luck!
Old Jun 5, 2023 | 10:41 AM
bismic's Avatar
bismic
Hopefully you chose some quality injectors. There is a lot of marginal quality choices out there ........................
Especially with injectors, "new" doesn't always mean "better"!
Old Jun 5, 2023 | 04:27 PM
8lug's Avatar
8lug
I was looking at the Motorcraft Remans at Rockauto. Is there a better choice?
I cannot find Motorcraft dummy plugs & standpipes or nipple seals. What would be a good choice for them?
I will be doing this in a couple of weeks.
Thanks for the replies.
Old Jun 5, 2023 | 06:02 PM
bismic's Avatar
bismic
My preference is Auto Nation White Bear Lake for genuine Ford parts.
https://parts.autonationfordwhitebearlake.com/
They will have injectors and standpipes and dummy plugs.
If you need part numbers, just ask.
Old Jun 5, 2023 | 07:04 PM
Motohead911's Avatar
Motohead911
How is the health of your oil cooler, it is right there.
Old Jun 6, 2023 | 05:57 AM
8lug's Avatar
8lug
Did the oil cooler and Bullet Proof EGR cooler last summer.
Old Jun 7, 2023 | 12:09 PM
53jimc's Avatar
53jimc
HHC diesel has the upgraded nipple seals and nipples, fyi. They aren't cheap but they are good.
Old Jun 8, 2023 | 06:02 AM
8lug's Avatar
8lug
Thanks, they have a good article about this on here.
http://www.ford-trucks.com/forums/12...ole-story.html
Old Jun 8, 2023 | 06:53 AM
53jimc's Avatar
53jimc
Yes, that's a good article. It's the reason I finally went with the HHC seals/nipples. Every 6 months the top injector seals would fail. First would be long start hot, then long start cold or hot, then no start. Keeping my fingers crossed that these will last. Truck is still running good since November, knock on wood.
bashby
Mar 25, 2013 09:54 PM
B-Ryan 02
22
Sep 2, 2009 05:13 AM
ljutic ss
May 26, 2008 07:05 PM
Royson12
Dec 16, 2007 04:39 PM
