Heater delete
Old Jun 2, 2023 | 04:54 PM
5851a's Avatar
5851a
Heater delete
Has anyone ever found a heater delete truck in the dentside era with a heater delete? The cars could get them till around 65. Maybe something south of the border? Would like to see what they did with the right side vent. Just curious.
Old Jun 2, 2023 | 11:15 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I have never seen a "heater delete", now NO a/c ='s no R/H vent. With a heater only truck, you do not get dash vents like an a/c truck.
Old Jun 4, 2023 | 03:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
New US Federal safety standards went into effect January 1, 1966 for Passenger Cars, September 1966 for 1967 F100/350, Bronco & Econoline.
Passenger Cars, F100/350, Bronco & Econoline had to have as standard equipment: Heater and defroster, backup lamps, left hand outside mirror, lap seat belts
Canada was the same as US after January 1968, because vehicles assembled in Canada could be ordered from the US, especially from GA/NC/NJ/NY
These features were optional in other countries.
Old Jun 4, 2023 | 09:17 AM
5851a's Avatar
5851a
Thank you ND.
Old Jun 5, 2023 | 10:36 AM
tbear853's Avatar
tbear853
My '77 was originally a heater only truck, the passenger vent was only a door one could open under the glove box area. Originally, with bug shield, we got next to NO air through either vent (still has driver side vent) ... which was when I robbed two junked donors of their factory AC and spent a week of spare time fitting it all, including that big firewall hole and all the dash vents. Later, after getting it all going, came a day I removed the bug shield, and suddenly my kick panel vent was blowing great at speed. I'm on the edge of jumping into getting AC working again (like some new O-ring seals, drier, exp valve, comp shaft seal, R134a) as it eventually leaked down. Even with the bug shield out there on the hood, AC flow was low.
Point ...I have often wondered (and I still wonder) how well those dash vents would distribute fresh air with NO bug shield spoiling air over the hood so it misses the cowl vents, and with no evaporator core blocking flow (or maybe it doesn't block so much so that it could be left in place?) and the heater hoses turned off or bypassed and/or redirected with a H type 3 valve setup so that the heater core did not heat up. Maybe add some foil type insulation and / or a heat shield between AC housing and exhaust & right head?
Old Jun 5, 2023 | 05:33 PM
5851a's Avatar
5851a
Well, they work pretty well. In the spring open the wing windows and open the floor vents and head out on the highway. You will eat all the dirt you didn't clean off the floor.
Old Jun 5, 2023 | 06:03 PM
tbear853's Avatar
tbear853
As long as there's no lima beans in the floor ...
I guess I could "test" the idea, no AC belt, unplug compressor wire, make sure heater valve shuts, or temporarily place a U-turn at heater pipe inlet end of hoses?
Al Yelton
1997 - 2003 F150
Nov 23, 2021 11:16 AM
TWODOGS522001
Jan 17, 2012 09:42 AM
mcdonaldm
Aug 3, 2007 12:31 PM
cbfomoco
15
Oct 15, 2005 08:06 PM
69crewcab
Feb 27, 2003 10:40 PM
