C1095 abs code
Old Jun 1, 2023 | 11:35 PM
glovemeister's Avatar
glovemeister
C1095 abs code
Got a 1998 ranger that mostly just sits as a spare truck. The other day I saw the ABS light is on, so I pulled codes and saw c1095 which relates to abs pump.
Are there any fuses I can check?
Old Jun 6, 2023 | 08:04 AM
pawpaw's Avatar
pawpaw
No replies yet so will see if I can get things started. Have a look in the owners manual for the fuse locations, if you don't have one it can be downloaded @ no charge here Owner Manuals (ford.com).
If no joy there, have a look at the fluid level in the under hood brake reservoir & top up if necessary with Motorcraft PM-1 DOT-3 fluid.
Seeing as how this puppy mostly sits, while under-hood also look for signs of mice having nibbled on the wiring to the ABS motor.
Might be helpful to know if this is a 2, or 4wheel ABS system??? Some beginning thoughts for consideration, let us know what you find.
PJWhelan
Dec 27, 2021 08:58 AM
86scotty
Sep 23, 2012 11:22 PM
bashby
Sep 17, 2012 01:50 PM
71FoMoCo
Aug 25, 2010 04:13 PM
McGunner
1997 - 2003 F150
Apr 9, 2005 05:30 AM
