Total fuel system replacement.
Old Jun 14, 2023 | 11:05 AM
  #31
Desert Don's Avatar
Desert Don
Originally Posted by DPelletier
What rufushusky said; Ford did a better job utilizing the CP4 but the other (and more important reason) is that the CP3 won't fit in the available space so Ford couldn't go back to it like Ram did even if they wanted to.
Dave
Well, Ford *COULD* sit down with Bosch, Denso, or someone else that *COULD* design a better pump to fit where the existing CP4 is.
BUT, they will not do that because then said improved pump could *POSSIBLY* also be refro fit to go in ALL 6.7 PSD’s since 2011. OOPS…. Ford *MIGHT* have to pay that bill when all the lawyers get done.
Old Jun 14, 2023 | 11:22 AM
  #32
DPelletier's Avatar
DPelletier
Of course they could; just explaining why they couldn't just go back to the CP-3 like Ram did.
Dave
  #33
NedFletcher's Avatar
NedFletcher
The uptick in threads recently, and more people complaining in the chat on the Powerstroke Tech Talk livestream finally got me to break down and buy the DPK. Figure I'll run it and if it ever blows replace it with the S&S/Stanadyne pump, https://ssdiesel.com/dcr/. Seems pretty interesting.
Odds are it will never fail, but 400 isn't a bad insurance policy, if it works as intended.
Old Jun 14, 2023 | 12:37 PM
  #34
Desert Don's Avatar
Desert Don
Dave
Oh, I understand that point.
And on the CP4, most folks never have an issue with them; but when someone does (like me @ 20,000 miles) have a tendency to lose faith in the system. Even tho the next truck went 60,000 miles with no issues, the CP4 was always in the back of my mind whenever I drove it.
Old Jun 14, 2023 | 01:43 PM
  #35
johndeerefarmer's Avatar
johndeerefarmer
Since I have a ESP with 100k miles left on it I am not doing anything until it's up.
The Bosch CP4 fuel pump has an unusually high failure rate in the U.S., upwards of 7%, when compared to 1% failure rate in Europe (from Google). This has to be contributed to the sorry diesel fuel here. Either add an additive or use diesel with bio in it. Then drain your fuel filter regularly- not once per year!
If this takes you down to the 1% failure rate that's a fairly small chance.
Old Jun 14, 2023 | 02:51 PM
  #36
DPelletier's Avatar
DPelletier
Keep in mind that, even assuming the 7% is accurate (see below), the numbers would be less on Super Duties vs. Rams and GM's (when they used them) for reasons mentioned previously, specifically;
But more likely Ford's failure rates aren't high enough for them to want to change. Again IMHO ford did a better job on the low pressure fuel system than GM or dodge. GM IIRC didn't even use a lift pump, which boggles the mind. Dodge has had a spoty reputable with lift pumps going back to the VP44, even the intank pumps of 2005+ were hardly adequate and only provided 8-12 psi to the pump. Ford on the other hand has a system that flows three times what is required with pretty good factory filtration at higher inbound pressure.
No idea if "less" is 1% or 6%....just pointing out that I believe the 7% number would be all US CP4 applications and isn't specific to the 6.7. As far as actual failure rates go, it looks like 5-7% on the Duramax which doesn't use a lift pump, the Ford failure rate is almost guaranteed to be less;
How Common Is CP4 Failure? (caffemotor.com)
Dave
Old Jun 14, 2023 | 03:11 PM
  #37
ToMang07's Avatar
ToMang07
The US also has a MUCH HIGHER number of full size trucks on the road, 99% of the "pickups" over there are no bigger than a Taco.
Old Jun 14, 2023 | 03:43 PM
  #38
rufushusky's Avatar
rufushusky
I agree, CP4's were used on everything from full size pick ups to the Cummins diesel in the Nissan down to some VW diesels. That said, if I had a CP4 go toes up on me I wouldn't be giving it five star reviews regardless of how rare the failure would be.
Old Jun 14, 2023 | 07:12 PM
  #39
HeavyAssault's Avatar
HeavyAssault
Originally Posted by nortonrider
Quick update: after Ford told me they couldn’t get parts for 2months I looked south of the border and found my own- for $3k cheaper…
Dropped them off at Ford and they said, “thank you very much. Btw, none of these (OEM Ford parts) are covered under warranty as you did not buy them from a CDN Ford dealer.” Sheesh.
So, I went out and bought a nice, original owner ‘09 with a 6 speed manual and am doing a Ppumped 24v Cummins conversion. The Tremor will be going for sale as soon as it’s out of the shop. Bye bye overly complicated fuel system!
Old Jun 14, 2023 | 07:54 PM
  #40
chadstickpoindexter's Avatar
chadstickpoindexter
Yep, the S&S DPK (especially on the 20+ MY's with pinned buckets) is our best bet. Well, that and using a good fuel additive and draining off a least a few oz of fuel from the WIF each month.
Old Jun 16, 2023 | 02:51 PM
  #41
acdii's Avatar
acdii
With S&S now having a viable non CP4 replacement pump that works better then the stock one, who's to say Ford can't be CA sued over it?
kulboy
Mar 18, 2023 10:30 PM
Darren Moore
Oct 9, 2021 05:25 PM
tolliewolly
6.7L Power Stroke Diesel
37
Jan 17, 2014 11:26 PM
gotcurb
6.4L Power Stroke Diesel
Jan 9, 2011 09:02 AM
exiled
Oct 29, 2007 05:59 PM
