Brakes??
Old May 23, 2023 | 12:53 PM
BamaBiggDaddy's Avatar
BamaBiggDaddy
Brakes??
I have a 62 F100 unibody has inline 6. my question I have the CPP kit for disc conversion they had all kind of directions for spindle and caliper install but fell flat on master cyl. The biggest question I have with the new dual bowl should I still route thru thr divider down behind steering gear box? Or run new lines (which I want to do since these seem to be original all the way back) The question is still the little divider?
Old May 23, 2023 | 06:15 PM
john jamieson's Avatar
john jamieson
Split the system and run new lines. No telling what kind of rust and gunk are in the old lines.
Old May 24, 2023 | 06:17 AM
Anatta's Avatar
Anatta
If you’re running discs on the front then you’ll want to ditch that splitter and use a proportional valve instead
Old May 24, 2023 | 06:34 PM
William's Avatar
William
About those proportioning valves. Disk/Drum valves are readily available and are not expensive, about 45-50 bucks. The ones I bought were marked "PV2" and were easily installed...one issue..., the outlet to the rear fitting is 9/16 x 18 but the line size is 1/4 inch. Your truck uses 3/16 inch line throughout. The 1/4 inch line flange on the PV2 will not fit properly. You may get away with using a 3/16 line on a 1/4 inch flair fitting but it is likely to leak. The solution is to locate a PV2 that has a 9/16 x 18 with a 3/16 outlet flair. The other possibility is use 1/4 inch line to the rear like GM does. I would talk with CPP about this issue an see if they can help.
Old May 24, 2023 | 07:02 PM
BamaBiggDaddy
Thanks guys the 1/4 line sounds good but then have to redo block in back gonna try ans stay as original as I can. Talked with CPP and they had some recommendations so propbably followup with that.
Old May 24, 2023 | 08:10 PM
BobbyFord's Avatar
BobbyFord
This is the valve that’s on my 63 Unibody.
3/16 line, front and rear.
https://www.carolinaclassictrucks.co...150-valve.html
This is a list of parts that bolt in, everything except the combo valve and booster brackets was bought at the local parts store:
1972 F100 brake booster brackets
Cardone 54-73515 brake booster
Cardone 13-1617 master cylinder (75 F100 disc.)
Carolina Classic Trucks disc/drum proportioning valve (73-79 F100/F150.)
Standard SLS66 brake light switch
Moog 8455B king pin set
Old May 26, 2023 | 09:36 PM
tbm3fan's Avatar
tbm3fan
Just so people know that is a junction block just behind the steering gear.
chucks65
Feb 6, 2018 01:01 PM
OldgreenF1
Jan 10, 2017 08:07 PM
Pappys53
Dec 27, 2008 01:44 AM
F100PxDriven
Apr 22, 2003 05:04 PM
1 Big Mike
Jan 17, 2003 02:40 PM
