Disc brakes conversion
Old Dec 17, 2008 | 11:14 AM
Pappys53's Avatar
Pappys53
Looking at disc brakes conversion kits, they say that the grease inserts may need to be moved. Those who have put disc brakes on the front of their trucks, what did you do?
Old Dec 17, 2008 | 12:12 PM
DR Smith's Avatar
DR Smith
I used a kit from{ master power brake in Cal.} and their directions said the same thing but i was able to use a die grinder on the mounting brackets,to give enough clearance for 90 degree fittings.It is a little hard to line up the grease gun but it does work.
Old Dec 17, 2008 | 06:35 PM
ghall's Avatar
ghall
I moved the fitting...
but if i had it to do again, would probably try clearancing the bracket...
live and learn... and one is probably as hard to do as the other.
Old Dec 17, 2008 | 06:53 PM
3798j's Avatar
3798j
I also removed some metal from the caliper mounting brackets (it didn't take much). It allowed enough clearance to install a 90 on one side, and a 45 on the other. My kit was from ECI. I agree with DR Smith, it's a liitle hard to get the grease gun on, but it definately can be done.
Old Dec 17, 2008 | 08:21 PM
grumpy46's Avatar
grumpy46
did the same
Old Dec 17, 2008 | 08:41 PM
gusso's Avatar
gusso
Why not do what the instructions say? Move it. Very easy to drill (with proper size)
and tap with proper size. VERY EASY.
Gary
Old Dec 17, 2008 | 10:24 PM
dongc1's Avatar
dongc1
It seems some spindles are different than others. I put a ECI kit on my 49 and did not have a problem at all. I had another set of spindles that I compared with the ones on the truck. The spare set would have required drilling new holes for the grease fittings. For once I was lucky.
Old Dec 27, 2008 | 01:44 AM
t900enforcer's Avatar
t900enforcer
We put on a kit from CPP and drilled the new holes as instructed. It was no big deal and worked fine.
T900enforcer
moose79
Mar 26, 2016 09:07 PM
Walwal44
27
Nov 25, 2014 12:41 PM
HogTied
26
Nov 19, 2014 01:43 PM
kodiak14
Dec 9, 2013 11:19 AM
