Traction Lock - Sounds Cheap
Old May 21, 2023 | 11:13 AM
SpeedThrills's Avatar
SpeedThrills
Does this sound okay? (I hope so, I bought the last one!) It sounds cheap. It's $330 at Summit.
I'm going to add a limited slip (currently open) and change from 2.94 to 3.31 gears on my 95 F150 w/ 300 and 5 spd. I'm looking to improve towing and improve traction in the snow while I'm at it.https://www.ebay.com/itm/29417128730...3ABFBMuOTIrIdi
Old May 25, 2023 | 08:22 PM
DaveMcLain's Avatar
DaveMcLain
Good deal!
Old May 25, 2023 | 09:40 PM
SpeedThrills
Originally Posted by DaveMcLain
Good deal!
Thanks Dave, I hope so! Going to start looking for deals on a r&p next, along with an install kit..
Old May 26, 2023 | 09:31 AM
mark a.'s Avatar
mark a.
2.94 to 3.31 isn't much of a jump. With a 5 speed overdrive I'd at least go with 3.50's maybe even 3.89's if I was pulling a trailer a lot.
Old May 31, 2023 | 09:18 AM
SpeedThrills
@mark a. Sorry for the delayed response.
First, I was wrong, I have 2.73's presently. (Old fartitus!)
It has a 300 six cylinder. Peak torque of 260 (I may have a little bit more; it's lightly modded.) at 2000 rpm. You'll see below, that matches my towing rpm @ 65 mph, with the 3.31's.
The M50D trans has a 3.90 first gear and a .80 5th.
And I should mention that I don't tow a lot.
With the 2.73's, I have an overall 1st gear of 10.65, and in 5th, it's 2.18. At 75 mph, in 5th, with a 28" tall tire, it revs at 1960 rpm.
With the 3.31's, I'll have an overall 1st gear of 12.91, and in 5th, it'll be 2.65. At 75 mph in 5th, with a 28" tall tire, it'll rev at 2385 rpm.
That'll be 425 higher at 75 mph, than with the 2.73's. That'll only be when not towing, as I'm not towing at 75 mph! At 65 mph, with the 3.31's, it'll rev at 2070. (1700 with the 2.73's.)
With that steep 3.90 1st gear ratio, if I put too much gear in it, 1st will be about worthless, as I see it.
I used the Wallace Calculator.
Anyway, I have the Traction Lock, and I just ordered the 3.31's. Also, I ordered the install kit from Ratech.
A1C DiMaggio
Oct 11, 2009 03:56 PM
Prozon
Offroad & 4x4
23
Dec 11, 2008 12:08 PM
operator exmark
Jul 24, 2007 07:21 PM
horizonhuskies
26
Nov 19, 2003 05:04 PM
