ball joints
Old May 20, 2023 | 04:18 PM
rich1785's Avatar
rich1785
ball joints
I have an 85 F350 4X4, doing the ball joints.
I Bought Moog because they have had good quality, I installed the new joints but the lower spins when I try to torque it, It doesn't spin in the knuckle but the joint internally spins making it impossible to tighten. I replaced it with another and it does the same. I have done many ball joints and never had this happen on quality ball joints. Any suggestions? I have had this happen on an old worn-out joint and had to cut it out but never when installing ball joints.
Old May 22, 2023 | 08:20 AM
knottyrope's Avatar
knottyrope
put a jack under it to apply some pressure to lock in the taper
30 for lower
tap upper collar down
70 upper
then 150 lower
check for free movement
afonda
24
Aug 4, 2022 11:58 AM
yzf450motoxrider
Jan 25, 2022 09:06 PM
True Patriot
Jul 9, 2021 11:56 AM
jhobbs26
6.4L Power Stroke Diesel
Jul 5, 2018 02:01 PM
ObiWanJak
May 19, 2003 02:01 PM
