Speedometer cable question.
Old May 20, 2023 | 03:56 PM
AlewisIII's Avatar
AlewisIII
Hello all my son has a 86 f250 6.9 diesel extended cab 4 speed, he installed a 5 speed transmission from a 92 f250 7.3 diesel. transmission works great but only problem is how to hookup speedometer cable or is it possible?
Old May 20, 2023 | 04:41 PM
rla2005's Avatar
rla2005
1992 and up trucks use an electronic speedometer/odometer, there is no drive gear on the output shaft.
No easy way around this one that I know of short of disassembling the new transmission to swap output shaft and tail piece with an older 5 speed trans.
Old May 20, 2023 | 06:06 PM
AlewisIII's Avatar
AlewisIII
Ok thanks...
Old May 21, 2023 | 06:08 AM
EPNCSU2006's Avatar
EPNCSU2006
Assuming it was original to the '92, the rear case housing part number was the same between electronic and mechanical speedometers. It may even have a speedometer gear in it already, with the cable socket plugged. The first 7.3 transmission to show a spacer instead of a gear was in '94.5 with what I assume is the first powerstroke. I attached some PDFs that show what I'm talking about.
File Type: pdf
File Type: pdf
Old May 21, 2023 | 08:10 AM
rla2005's Avatar
rla2005
Perhaps you might get lucky based on the info from the previous response.
Old May 21, 2023 | 12:58 PM
tjc transport's Avatar
tjc transport
i ain't rite
another option would be a small GPS based speedometer.
Old May 22, 2023 | 09:02 AM
solanum's Avatar
solanum
Is this a RWD or 4WD trans? If 4WD the cable connects to the transfer case. If RWD there is usually a blanked off hole in the tailshaft housing. No idea if there's a actually a gear inside the hole, but it's easy enough to check if you find the hole.
Old Jun 6, 2023 | 06:59 PM
AlewisIII's Avatar
AlewisIII
Yep we found the hole but like you wrote but it's blocked off inside. How would find out if there's a gear inside?
Old Jun 7, 2023 | 04:31 AM
EPNCSU2006's Avatar
EPNCSU2006
You would have to remove the output yoke to find out. If you do that, be sure to torque the nut to spec when reinstalling. Does it look like it's a removable plug or is the aluminum just not drilled through? There's a note in the ZF documentation to use plug number F2UZ-7H183-A on 4x2 with electronic speedometer.
Old Jun 7, 2023 | 05:21 PM
AlewisIII's Avatar
AlewisIII
Hey guys this is what it looks like....
Old Jun 9, 2023 | 04:46 AM
EPNCSU2006's Avatar
EPNCSU2006
I'm sure it could be done, but I don't think it would be an easy addition without disassembling the transmission.
RadioControlGuy85
Dec 12, 2012 04:55 PM
timrocker
Jun 26, 2007 09:56 PM
pbrassey
13
Dec 6, 2002 01:21 AM
