Rear Driveshaft for 1988 F150
Trying to find a rear driveshaft that can be used in place of a missing driveshaft for a 1988 Ford F150. Wheelbase is 133". Transmission is an AOD with a 5.0 engine.
Last edited by Arogers8337; 05-18-2023 at 08:09 PM. Reason: Forgot to specify rear driveshaft
It is too bad you do not live near me
I have a few in my crawl space, you could sure have one
Junkyard or build one for more dough
Just checked and you are in CO?
Might be close enough for a trip over here to SLC
I need to make sure which ones I have
Your 133WB had a driveline center support bearing right?
Any idea of length?
Any idea of length?
What do you mean by driveline center support bearing? Are you talking about the crossmember holding ip the transmission mount? As for length the driveshaft is missing but I've done some research and its supposedly 65" but can't confirm whether that is actually true.
Also yes I am in CO, might just be worth the drive if you do have it.
Did you look it up on car-part? There might be one near you.
vortec
11-02-2007 10:34 PM
