Sponsored by: Real Truck
Front suspension
Old May 18, 2023 | 11:08 AM
Fish2fry's Avatar
Fish2fry
5th Gear
Front suspension
2007 F350 4X4, added a RanchHand bumper and a steel cable 12000LB winch, I Carry a 300 gallon water tank, for fires and shallow wells, most driving is off road on a 46,000 acre ranch, the front is bottom out hard, any help to fix it I sure would appreciate any info.
Old May 18, 2023 | 11:19 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Sounds like your factory springs were about worn out before you added a bunch of weight to the front of the truck. BEST solution is new, heavier-duty springs that can accommodate the extra weight. That's going to make your suspension less flexible though.
I suppose you could go with softer bump-stops or spring-over shocks to try to lessen the impact from bottoming out, but those are really just bandaids.
Old May 18, 2023 | 02:10 PM
nydiver's Avatar
nydiver
Try a set of springs for a plow prep packaged diesel or you could remove the springs and install air bags.
7000 5C3Z-5310-AA
6500 5C3Z-5310-BA
6000 5C3Z-5310-CA
Old May 18, 2023 | 05:23 PM
Pickupmanx2's Avatar
Pickupmanx2
I'll have to dig through pics, but I had a set of springs on the front of my '02 F350 dually, they were 3 leaf, with a Ford # stamped on them, and the folks at ATS had no idea where they came from, the new front springs are great, granted I did add 2 from the mini spring pack they sent me to bring the front up a tad.
https://www.ford-trucks.com/forums/1...-drw-help.html
Old May 18, 2023 | 11:07 PM
WWR's Avatar
WWR
OP's '07 is coils
Old May 19, 2023 | 07:05 AM
jav_eee's Avatar
jav_eee
I’d love to see your fire extinguishing setup. We have a truck we want to use for the same purpose, though not on nearly as much land as you.
Old May 20, 2023 | 06:48 AM
speakerfritz's Avatar
speakerfritz
summo springs. They are over sized bump stops about the size of a coke can. They come in 1000lb, 1500lb and 2500lb reverse spring force sizes. Much easier to install and more effective than a incremental front spring upgrade.
whiskey08
Oct 9, 2019 11:22 AM
jeronlines
Jan 30, 2014 05:57 PM
TheTowingCowboy
Sep 29, 2010 07:42 PM
PhilfromFlorida
Dec 4, 2007 09:27 PM
PhilfromFlorida
Dec 4, 2007 07:36 PM
