82K miles plug, wire and boot change
Hello, Ford F-350 2014 6.2 gasoline. I have this problem
The car is of the lowest configuration, I changed PCM and BCM but it is not programmed, I installed a 2013 F-250 6.2 gasoline, which is 4-door, but it is also of low configuration, but still it is not programmed and it says that there is a problem with the immobilizer (pats) error. It does not turn the engine and the starter. These computers are removed from one car, they do not match the code of the old computers of my car, but I installed PCM and BCM of both the same car. I also installed a Taurus BCM computer, on which the engine runs for 2 seconds and shuts off, they tell me that I need a BCM computer that corresponds exactly to the code of my car, but they cannot guarantee that the car will start, maybe someone knows what is the matter and what is the problem with me
Denny
https://www.vehicleservicepros.com/s...her-procedures
Got my plugs changed today and it took 2.5hrs without removing the inner liners. Wasn't as bad as the 2013 I used to have, worst plug to mess with was the lower passenger side plug that was under the oil dipstick because it was a little harder to find room for the wrench. Used MC plugs and wires and AC Delco boots because that's all I could find in stock.
Most of the resistors has some corrosion starting but nothing as bad as some of the other pictures shown. I did take a screwdriver and scrape inside the coil to get the contact shined up a bit before putting it back together. Three of the top plugs had some white corrosion dust around the boot and plug but the electrodes all were in pretty decent shape for having 50,000 miles on them. Put dielectric grease on both ends of the boot and the rubber end of the wire going to the bottom plug, added a very small dab of anti seize to the plug and torqued to 18lbs.
Only issue I ran into was that I broke off the retaining tab on one of the plug ports on one coil. I could not get the plug to hold together to where I would trust it so I bit the bullet and bought a new coil and will keep the damaged one for an emergency spare. Also noticed eight of the plugs are different and not sure why that is. The plugs are what the factory put in so there must have been a reason for that. I did start another thread on the plug differences.
Halp me plase
Hello, thank you for answering my question. I bought F-250 6.2 gasoline PCM and BCM computers, my car F-350 6.2 is easy to unlock, it has a non-programmable ignition, therefore I bought a car computer that has the same key, it's just a 4-door F-250, I also bought other electric keys that Yes, the car has it. The Ford electrician tells me that these computers will not work for my car. But I also bought a taurus BCM computer that turns the engine on and off in 2 seconds, I can't understand why the f-250 6.2 BCM and PCM computer doesn't work and why the taurus 3.5 BCM computer works half as well when the taurus has so much more features. Actually I am installing and setting up a new car because the engine is good and running I am installing working car computers BCM and PCM why can't these computers fit my car. Sorry for writing so much and having so many questions, but I've been working on the car for 1 year and we still haven't heard what the problem is
no one can help me, I'm tired
no one can help me, I'm tiredThread
Zoidberg
18
Jun 3, 2020 08:21 PM
