Sponsored by: Real Truck
2006 Header Panel on 2002 Excursion
Old May 15, 2023 | 08:15 PM
jthand55's Avatar
jthand55
Trailering
Hello all,
I have a 2002 7.3 excursion on which I did a 2006 headlight and grill facelift. I did the usual cutting out of the header panel behind the headlights to fit the new ones. However, after years of bumpy roads and getting backed into, the header panel is cracked everywhere and barely holds the headlights in. So my question is, if I replace it with a 2006 header panel, will it directly fit onto my 2002? I was thinking about this to try and avoid cutting out the headlight holes again and keeping it stronger. They seem extremely similar but I figured I'd ask here first before ordering.
Edit: also I should mention, I am using a 2002 conversion grill. So it is still the regular height of the 2002 grill that fits the original bumper.
Thank you!
Old May 15, 2023 | 08:24 PM
WE3ZS's Avatar
WE3ZS
It should bolt right in, several folks over in the EX forum have upgraded the header panel to make the later lights fit correctly.
Studawg
May 9, 2021 01:40 AM
Technologiq
May 18, 2015 09:39 AM
diehardstroker
Aug 25, 2013 05:50 PM
aklim
May 19, 2008 11:10 PM
billygoat
May 26, 2007 03:54 PM
