Clunk going in reverse when shifting multiple times
Old May 15, 2023 | 07:04 PM
Anonymous12's Avatar
Anonymous12
I have a 88 f-150 it’s got an aod. I never thought about this until I had a suspicion of overdrive not working from being told its rpm is too high for the setup. But it is making a clunk when put in reverse it only does it when I shift multiple times like going P R N D D 1 and back though again to check the fluid or making 3 point turns or something. It’s only reverse it does this.
Old May 16, 2023 | 09:37 AM
jas88's Avatar
jas88
Check your u-joints first.
Old May 16, 2023 | 12:06 PM
Hit Man X's Avatar
Hit Man X
No OD shift could be a roached band, OD servo out of case, or even misadjusted TV cable. Too tight is better than too loose.
Chock wheels and with truck off, verify you have all positions too. Easier with help.
https://m.youtube.com/watch?v=6L3hNzxdiYw
Old May 16, 2023 | 01:31 PM
Anonymous12
I drove it, it has OD. But I need to figure out the clunk. I’ll mess with the U-Joint when I change the diff fluid.
Old May 16, 2023 | 01:43 PM
rla2005's Avatar
rla2005
Excess slop in the rear axle can do it as well. Worn spider gears, excessive ring to pinion clearance (i.e. backlash), etc. Every little bit of extra clearance adds up pretty quickly. Not uncommon on any old vehicle. If someone did swap in new gears perhaps the setup was not optimal.
Old Jun 14, 2023 | 01:49 AM
Anonymous12
I forgot about the issue until today when it started slamming into reverse when I was backing into a spot and correcting my terrible parking job. I shifted into reverse it didn’t clunk, shifted into D, then R, made a clunk repeated that and it clunked more. It’s U-joints are fine ones new the other I verified it’s good. I think it’s the transmission, not much I can do about it now it reverses fine but I’m more so curious as why it does that. My dads 05 Chevy with the 5 speed Alison did it, but not unless you did it like 20 times when we were messing with the lines on the backup camera.
I’ll record a video of the noise later.
I can feel it when it does it to.
Old Jun 14, 2023 | 01:04 PM
wwhite's Avatar
wwhite
I have a 94 e4od, brand new rebuilt rear end, clunks into reverse only when hot, sometimes really badly, super smooth when cold.
I have determined my issue is in the tranny, tail shaft or previous owner mucked with pressure to give firmer shifts in forward gears, but slams in reverse.
Liquid10Rider
Jan 17, 2023 09:12 AM
Patina65
May 16, 2021 06:53 PM
pud
Dec 29, 2008 02:21 AM
Rev440x
2004 - 2008 F150
Nov 11, 2005 12:47 PM
