Barn Door Driver’s Side Cable
Old May 15, 2023 | 03:17 PM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
Anyone have a part number for this part, or rather the equivalent E-350 one that works.
I saw this video where a guy used an E-350 cable because the one for the Ex has been discontinued.
Any direction would be helpful.
Thanks.
Old May 15, 2023 | 05:48 PM
01__Excursion's Avatar
01__Excursion
Which barn door? The left door handle and cable are showing still avail.
Old May 16, 2023 | 06:00 AM
ASFC27FTFBQ
Thanks 01_Excursion. Ordered it from The Ford Store on Amazon. Maybe, by ordering through Amazon, it will be the correct part.
I was looking for just the cable, but I might as well get the whole kit and be assured that the handle won’t break, as well.
Thanks again.
Old May 16, 2023 | 02:33 PM
2002Limited's Avatar
2002Limited
I got this part as well. Hardest part was drilling out the original rivets on the bottom of the old one. Got to be careful leveraging yourself against the fiberglass doors.
Old May 16, 2023 | 05:07 PM
srkrit's Avatar
srkrit
https://www.ebay.com/itm/22431691248...mis&media=COPY
This is the one I used to replace cable when I repaired mine- worked perfect
Old May 23, 2023 | 04:12 AM
ASFC27FTFBQ
Just installed it last night. Yes, had to drill out two (2) aluminum rivets that held the handle in place and then replace with nuts and bolts. Clearance for the passenger side door was not a problem. The Torx 27 bolt on the bottom was a little tougher to loosen because they are secured from the factory with blue Locktite. Needed to push in pretty hard so I did not round off the screw head.
All in all, one of the easier projects.
Thanks 01_Excursion for the link.
Old May 23, 2023 | 05:09 AM
01__Excursion
Is the actuation smoother? I just installed the liftgate latches with cables, and center lick motor assembly, and what a difference in opening the gate that I didn't realize was possible.
MustangMatt96GT
20
Feb 12, 2020 12:19 PM
Texas Mad Man
Jun 9, 2017 08:05 PM
mkmchu
Feb 23, 2014 01:29 PM
warware
Jan 15, 2008 07:57 AM
svfd1231
Aug 19, 2003 03:12 PM
