Need help/advice
Old May 14, 2023 | 10:47 PM
Kobra's Avatar
Kobra
Need help/advice
Hi all,
I just got done replacing rear leaf springs on my 2002 Excursion, however I have run into issues now that it is on the ground.
I was able to get the bolts and nuts in the front hanger and rear shackle and use a floor jack to push the axle into place so that the center pins would align. I then got the U bolts on, snugged down, put the tires back on and lowered it down so the full weight is on the suspension.
Now comes the problem... I am able to torque the front hanger bolt and the rear bottom shackle bolt to 185 ft-lbs... however I cannot get the rear top shackle bolt to tighten to 185 ft-lbs. It wants to just keep spinning... even with a wrench on the nut pushed up against the body/hanger to prevent the wrench from moving (ie holding the nut in place)... it just won't tighten to 185ft-lbs. Could I have messed up the threads already? Grade 8 bolts and nuts from ATS... so I don't think I would be able to hurt them hand tightening them, especially since I hit the 185 ft-lbs on the other bolts with no issue.
Looking for advice on what to do with the top bolts...
Sean
triple9jos
2015 - 2020 F150
Feb 24, 2021 11:57 AM
JethroF250
Mar 12, 2009 11:10 AM
cowboyty
Mar 24, 2007 07:09 AM
DS02F250
Dec 17, 2004 10:10 PM
