Adding Tachometer
Old May 13, 2023 | 07:02 PM
bruh1213's Avatar
bruh1213
4wd High
Adding Tachometer
I’m wanting to add an aftermarket tachometer to an 88 F250 that didn’t come stock with one. If anyone could shed some light on how to wire this up I would appreciate it! It’s a C6 trans if that makes a difference.
Old May 14, 2023 | 05:30 AM
yeet's Avatar
yeet
Just did mine this weekend. Signal wire goes to the tan/yellow wire on the coil. Mine is a 95 so your color may be different. It's the coil negative. red wire I went to the washer/wiper fuse (keyed hot)
white went to the dash lights fuse. Black to ground. It was pretty simple. Set the switch on back of tach to 8cyl.
Old May 14, 2023 | 06:23 AM
bruh1213's Avatar
bruh1213
4wd High
thanks that’s very helpful!
rogersdan
Jul 23, 2021 05:09 PM
zedsdead
May 13, 2021 09:30 AM
ReBilld
22
Aug 21, 2013 12:03 AM
acereplace
Aug 21, 2006 10:04 PM
Katt
Electrical Systems/Wiring
Jun 11, 2000 03:09 PM
