Upper lube
Old May 13, 2023 | 10:04 AM
ajsunnyB's Avatar
ajsunnyB
Upper lube
I've been looking for a valve cover Lube system that no longer is available. I have thunderbird valve covers. The lube sprays oil on the valve assembly. My lines are clear and I run Valvoline 40 weight racing oil. Lots of guys are running it in there Y Block 312 I change the oil.and keep it clean. And run an oil.pressure gauge Stewart Warner off the valve cover assembly. about 38 lbs at 55 mph. Has anybody else running valve cover lube system in their Y Block.AJ
Old May 13, 2023 | 03:22 PM
bigwin56f100's Avatar
bigwin56f100
It's an old bandaid fix for oiling problems. It's not needed when clean and fresh.
it actually pulls too much oil from the main gallery and then the lower end suffers
Old May 13, 2023 | 05:17 PM
ajsunnyB's Avatar
ajsunnyB
Okay Lead. I Was looking for some opinions about the system my gallery's are. Clean and open for right now. I've got my valve covers off and was inspecting the seals and the aluminum covers are really clean. Also removed the oil pan no sluggle in the pan just really checking to see what I got. So far I am pretty impressed. With my engine. The block is 312 and the heads are maybe 292 Y Block the numbers are kinda grounded off but still readable. Can you run that combination or can an upgrade cause the grinding off of a few letters?AJ
cjben
Apr 2, 2010 10:00 PM
jaye
Mar 31, 2009 02:10 PM
83maverickf-100
May 26, 2008 09:15 PM
77fordcrewcab
Jul 15, 2005 07:22 PM
CRJ900
13
Dec 20, 2001 01:14 AM
