2001 F-250 7.3 when accelerating and take my foot of the Pedal lights flash on the dash for a second and looses engine power for a second when I put my foot back on the pedal again I regain engine power and the lights go off no codes are set and it doesn’t happen every time I do it just every now and then this happens within like 2 or 3 seconds
What lights go on and off? Warning lights? Dash lights? Turn signal lights?
battery light comes on some of the time
service engine soon light ones on
and I wanna say the abs too there May be one more but I couldn’t see them fast enough
Check the ground for the fuel pump. Make sure all chassis grounds and clean and tight (no green crusties). Check connector at the fuel pump control module.
