strange electrical problem
Old May 12, 2023 | 10:36 AM
fredgullatt's Avatar
fredgullatt
1st Gear
This makes no sense to me, I'm hoping for a little help. I recently rescued a 1994 F150 xlt been doing alot of work on it, replaced both gas tanks and fuel pumps, shocks, coil springs, radiator, water pump, battery etc. lots of cleaning and painting things mostly under the truck so far. My issue is we have got the truck running but if I turn on the head lights the engine stops immediately, its like a kill switch. I feel like it must be going to ground or shorting something but have no idea about the history of this truck, or why it was parked years ago, so this could have been there before. I just suspect it is something i did.
Thanks for any ideas
Old May 12, 2023 | 12:07 PM
toolman60's Avatar
toolman60
I would say check all your grounds first. There are a couple up on the radiator support. Then I would check the headlight switch.
Old May 12, 2023 | 03:15 PM
sandymane's Avatar
sandymane
This picture is the driver side headlight ground and there is another on the passenger side.
Old May 14, 2023 | 05:17 AM
manicmechanic007's Avatar
manicmechanic007
If an aftermarket radio, check the wiring to it
Common for installers to mistakenly use the lt blue with red illumination wire for power
JoeVR
19
Aug 27, 2016 10:18 AM
DyceDesign
May 31, 2009 01:10 PM
genisis
Jan 31, 2004 07:44 PM
blackened
25
Nov 29, 2003 02:36 PM
