1964 Dash lights question.
Old Jul 21, 2009 | 09:54 PM
flipklos's Avatar
flipklos
1964 F100 2WD.
My dash lights worked fine untill a week ago Dimmer functioned and the whole nine yards. Never seen a problom with them. We drove to get grocries one eve and they worked on the way down and then when I left they were dead. The running lights work and I cannot locate any fuse for the dash lights in the fuse panel.
My wiring book for the 64 shows a fuse on the switch itself for the dashlights. Where is it and can I change it? If it is not that I assume it is the comutator in the switch itself and will need replacing.
Any thoughts?
Old Jul 21, 2009 | 10:02 PM
gritsngumbo's Avatar
gritsngumbo
Does this help at all?
(click to enlarge pic)
Old Jul 22, 2009 | 01:38 AM
camperspecial65's Avatar
camperspecial65
If the fuse doesnt fix it, the other thing that controls the dash lights is the light switch ****...it rotates...one way all the way turns on the dome light, the other extreme turns off the dash lights...in between though it adjusts the brightness of the dash lights.
A common thing is the spring in the headlight switch which works the rheostat for the dash light breaks or corrodes and thus kills the lights.
You also may just have the **** turned all the way off or in a spot on the rheostat that turns them off...just rotate the **** a bit can usually help get them on.
- cs65
Old Jul 22, 2009 | 06:16 AM
flipklos's Avatar
flipklos
So that little bitty fuse on the fuse pannel is the suspect!
I will check that out after work.
Old Jul 22, 2009 | 08:30 AM
Erich.Vongeist's Avatar
Erich.Vongeist
I have been having the same problem,
I think I'll check for that fuse too.
Thanks,
Erich
Old Jul 22, 2009 | 09:45 AM
Erich.Vongeist
Yeaaaa! I have dash lights now! That 2amp fuse was the culprit!
Thanks,
Erich
Old Jul 22, 2009 | 07:32 PM
flipklos's Avatar
flipklos
Fuse is bad. Looked fine but a current wouldent travel.
Old Jul 23, 2009 | 08:27 PM
flipklos's Avatar
flipklos
Both the panel lights and the parking light fuse were bad. Funky thing was I had working panel lights.
I think what may have caused the problom is I wired my radio memory into the constant hot for the lights. I belive the old fuse just finaly gave in.
Thanks yall.
Old Nov 7, 2022 | 06:59 AM
ttoppins's Avatar
ttoppins
Trailering
I know this is an old thread but I just picked up a 1964 F250 that has the same issue. No backlight on instruments and no signal indicator lights on dash. Can you repost this image/diagram? Thank you!!
Old Nov 7, 2022 | 07:40 AM
Crop Duster's Avatar
Crop Duster
Welcome to FTE!
The problem with replying to old threads. The person you are asking hasn't been on since 2016.
Your fuses are located on the headlight switch if that's what you are asking. It is best to start a new thread if you have a problem, you can't sort out.
Old Nov 7, 2022 | 07:49 AM
ttoppins's Avatar
ttoppins
Trailering
Thank you. Yes I knew it was a longshot. I will create a new topic. I know where the fuses are but wanted the diagram showing the connections. Trying to sort out why my dash lights are not working…switch vs corroded connection, fuse etc. the very short glass fuse that some have discussed seems to have continuity so I’m trying to track down the culprit. The bulbs work and were previously replaced with LED’s.
cghstrojan08
29
Oct 15, 2024 09:14 PM
AaronEZ
1983 - 2012 Ranger & B-Series
Jun 23, 2022 06:44 PM
DesertZuki
May 15, 2015 11:03 PM
Jasonf150
Nov 8, 2014 11:51 PM
steedracer
Nov 12, 2010 08:03 AM
