Speedometer gears question
Old May 10, 2023 | 08:27 AM
bald59's Avatar
bald59
Can someone tell me what the factory driven and drive gear sizes are.
1959 f100 4wd 4 speed
Old May 11, 2023 | 03:59 PM
bald59's Avatar
bald59
If this helps. What I am trying to accomplish is the right size gears for my setup I have now. the tire size is the only part that has changed from factory. They are 35inch.
Old May 11, 2023 | 07:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bald59
Can someone tell me what the factory driven and drive gear sizes are. 1959 F100 4WD 4 speed.
1959 F100 4WD with T-98 (F) 4 speed & 9" rear axle with 3.89-1 (02) rear axle ratio:
B9C-17285-A .. Speedometer DRIVE Gear - 7 teeth / Obsolete
01T-17271-B .. Speedometer DRIVEN Gear - 19 teeth / Use with 6.50-16 - 7.00-15 - 7.00 x 17 tires / Obsolete
01T-17271-C .. Speedometer DRIVEN Gear - 20 teeth / Use with 7.10 x 15 tires / Obsolete
01T-17271-D .. Speedometer DRIVEN Gear - 21 teeth / Use with 6.70-15 tires / Obsolete
A is the front axle ratio: 3.92-1
Old May 12, 2023 | 04:36 AM
bald59's Avatar
bald59
Thank you so much for the help
64GRAINBODY
Jun 1, 2019 06:08 AM
65oldie
17
Oct 26, 2015 09:41 AM
droppedf100
Feb 19, 2007 12:53 AM
mustange70
Apr 23, 2003 10:33 PM
jowilker
Jun 1, 2001 09:41 AM
