Hi folks, the blower motor in my 2013 E350 Super Duty cutaways chassis has stopped working. The blower works fine if I connect 12V to it, I've checked the resistor pack which is fine, fuse and relay etc. Can someone help me out with a wiring schematic?
I see people mentioning the AutoZone website so I registered but don't see any wiring diagrams
The link shows one page for your 2013 without blurring. This drawing shows the blower for a cutaway chassis. Note there is a relay but the drawing shows it is not used in the cutaway. I'll bet that relay is used in your van. Check the owners manual for location.
Hi Don, you were correct on the relay. I was fooled initially because the relay because you could feel the operation of it but when I finally pulled it out and measured the resistance across the contact it was around 200 ohms so must have been badly charred. Thanks for the help again.
