Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Vin Help - 1973 Grumman Olson Step Van
Old May 9, 2023 | 07:44 AM
Dware's Avatar
Dware
3rd Gear
Post Vin Help - 1973 Grumman Olson Step Van
Looking for a little help decoding a vin on a recently purchased 1973 Grumman Olson Step van. It has a 10 Digit vin, which i can only find relative info on 1940's fords ;/ Simply hoping to get some basic info on the truck.
Vin : P4OAL58673
Any help would be greatly appreciated!
Old May 9, 2023 | 05:56 PM
85e150's Avatar
85e150
Welcome to FTE!
The VIN issued by Ford, which it appears this one was, would be 11 digits for this model year.
As best I can do:
P40 = P400 Parcel delivery chassis
A = 240 1V six cylinder in line gas engine
L = Michigan Truck Assembly Plant
Looks like you are missing a letter ahead of 58673. All serialized numbers for model year 1973 are prefaced with a letter, in the range of Q to S.
For model years '73 to '79, all serialized numbers in the VIN are prefaced with one or two letters.
You may have a warranty tag riveted to the body, possibly on the dash or firewall that has the VIN and axle, trans and other info coded on to it.
Old May 9, 2023 | 06:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It has a 10 Digit VIN / Simply hoping to get some basic info on the truck.
VIN: P40AL58673
The VIN has 11 digits thru 1980, you missed the letter that precedes 5 or the 5 may be an S and you dropped one of the following numbers.
P40 = P400 Parcel Delivery Chassis.
A = 240 1V I-6.
L = Michigan Truck Assembly Plant.
XXXXXX = This decodes to the year.
The Warranty Plate has far more info. On P350/400/500, it's riveted to the right (passenger) side of the radiator support.
Old May 9, 2023 | 06:21 PM
85e150's Avatar
85e150
Is there an echo in here????
Old May 9, 2023 | 06:38 PM
NumberDummy
I didn't know if you could decode a P series.
Old May 9, 2023 | 06:55 PM
85e150's Avatar
85e150
I never know until I actually do one....
Old May 10, 2023 | 10:37 AM
Dware's Avatar
Dware
3rd Gear
thanks for the info, picking up my van in the next few weeks and should be able to get more info then... cheers!
j_garm
Feb 6, 2023 12:54 PM
jzwick
Dec 24, 2021 09:12 AM
oldschoolvan
Jul 21, 2021 05:27 PM
tromano32
33
Apr 30, 2021 06:25 AM
Angel Tollens
General Automotive Discussion
Jan 3, 2018 09:08 AM
