Transmission noise
Old May 9, 2023 | 05:40 AM
Ford 82's Avatar
Ford 82
Trailering
Transmission noise
I have a 2019 F 150 3.5 with a 10 speed. The transmission from a dead stop makes a klunk noise when you accelerate . This also happen when it shifts 8th to 9th or 9th to 10th. I took the truck to Ford. They did a reprogram to see if the problem would go away. It now still has the problem but shifts from 1st to 3rd skipping 2nd and 3rd to 5th skipping 4th. They say the solution is a transmission rebuild.
Has anyone else had this problem? Does the rebuild cure the problem or does Ford have a problem with these transmissions?
Old May 9, 2023 | 09:29 AM
JKBrad's Avatar
JKBrad
Had a similar issue with our 2020 Navigator. It was acting up for awhile, not hold any higher gears well, and then under anything other than light throttle, it would hold 1st way to long, then slam into 4th. The dealer keep it for 2 weeks, rebuilding rather than replacing the transmission. Told me that Sun Gear 3 was shot. I asked why the transmission wasn’t replaced under the warranty and was told that there were none available due to high demand. That Navigator is now someone else’s problem.
Old May 9, 2023 | 12:32 PM
Ford Motor Company's Avatar
Ford Motor Company
Official Ford Pro Rep
Hey there. Can you please send over a private message with your VIN and the name/location of your local Ford dealer? I would like to look into your transmission concerns on my end!
Old May 9, 2023 | 03:15 PM
CKNSLS's Avatar
CKNSLS
Just a point. The transmission is engineered to skip gears. That's one of the "features" of the ten speeds.
https://fordauthority.com/2023/02/ford-f-150-10-speed-automatic-gear-skipping-explained-video/
https://www.ford-trucks.com/forums/1666200-10-speed-tranny-skips-2nd-and-4th-gears.html
Old May 10, 2023 | 12:05 AM
Bluegrass 7's Avatar
Bluegrass 7
You have 5 shift modes to select.
If you use ECO, the Trans will upshift 1 to 3 to 5, then on up, depending on how much throttle you apply.
Gears 8, 9 and 10 are all overdrive gears.
They should not bang up or down shifting.
If that is happening the shift timIng is out or the fluid line pressure is to high, for some reason.
In Wet/Snow mode, the shift pattern will also change.
In Tow Mode the gears will hang on longer before shifting for obvious reasons. A load is expected to be attached.
In M mode, you can up and down shift with the control button depending on where it's located. On the column lever or the floor shifter side buttons.
Good luck.
Old May 18, 2023 | 07:28 AM
donovan's Avatar
donovan
Ford Just bought back my 2019 f150 for bad transmission. I really do wish ford could have fixed the issuse. It sound like same issuse.
Ford put in a re-manufacture transmission which made it worse. Then the rebuild the re-manufacture and is was still bad. Then they tried again to rebuild the re-manufacture transmission and then it horrible. My under standing from reading is the bushings on the CDF clutch pack failing on many of the 10 speeds transmission. I had about 45k on my f150.
I hope your services center is better then mine.
For 2023 my trucks was in the shop for 3 car payments. Ford did not fight us on the buy back. I am watching to see when ford will find a permanent fix for 10 speed.
How many miles on yours.
Old May 18, 2023 | 09:54 AM
JKBrad's Avatar
JKBrad
The permanent fix for it is to quit their partnership with GM and go back to building the ZF licensed automatics. The current ZF is an 8 speed and is an outstanding transmission, even better than the ZF based 6 speed auto that F150s had before.
This is just my opinion, partly based on a bad experience in our Navigator. The Ford/GM 10 speed is over complicated, and combined with poor build quality I just don't see this transmission providing a long service life. It's the 5.4 3V of transmissions. Hopefully the aftermarket will respond with parts to beef it up, there will be a market with millions in service already.
Ford recently acknowledged that they have quality control issues. The first step is admitting you have a problem, and I commend them for that. Warranty claims for them have been through the roof in the last several years. Let's hope that the steps they take toward solving the QC issues work. My first step would be to simplify wherever possible. These trucks are getting very complicated and tech heavy. I'll take reliability over unnecessary complication any day.
How hard is it to make a reliable transmission? The automatic has been offered in Ford trucks since 1953, 70 years! You'd think they could get it right by now. Ford has had many excellent transmissions in the past. Then there's other things in these trucks. A moon roof that breaks easy, Ford has been offering them in various vehicles for over half a century then suddenly come 2015, they can't build a reliable one. The APIM failure in Sync3 radios are another example of poor craftsmanship. Again, I hope Ford take quality very seriously. I would really like my next truck to be a Ford, but I wouldn't buy a new Ford today.
That having been said. My 3.5 EcoBoost/6 speed auto 2015 F150 (XLT no moonroof) has been excellent. It's the best truck I ever bought new, and I've owned a lot of trucks over the years.
Old May 18, 2023 | 11:21 AM
Ford 82's Avatar
Ford 82
Trailering
Thanks for your reply. I have 43000 on my 2019.
Old May 18, 2023 | 11:25 AM
JKBrad's Avatar
JKBrad
Our Navigator needed the transmission rebuilt at 40k miles. We don't have it anymore, not just because of that, but because of all the other little issues that the dealer couldn't or wouldn't fix.
bubbabug
36
Sep 23, 2015 11:06 AM
MurderedoutF2
6.4L Power Stroke Diesel
Jan 31, 2008 11:27 AM
revbruce
1978 - 1996 Big Bronco
Mar 17, 2004 09:22 AM
