Single tank Fsv jump
Old May 7, 2023 | 11:27 PM
Boneshaker95's Avatar
Boneshaker95
5th Gear
Need some help on what wires to cut and splice to achieve gauge communication to single rear tank swap.
1995 F-250 7.3 PSD. Single rear spectra 38 gallon tank with beans sump.
Old May 8, 2023 | 05:31 PM
Franklin2's Avatar
Franklin2
The diagram I am going by is for a older model. If you have a switching valve on the frame under the driver's door area, and it has about 6 wires going to it, and you can find these color wires in the following instructions, we can assume it's the same.
Find the yellow with white stripe wire. That goes to the fuel gauge up front. Cut it.
Find the yellow/lightblue stripe wire. That goes to the rear sending unit. Cut it.
Splice these two cut wires together. That should make the rear sending unit work straight to the gauge. I would bypass the fuel lines at this valve also, splicing the two from the rear tank to the two going to the front.
Old May 8, 2023 | 07:53 PM
Boneshaker95
5th Gear
Ah ok ya the selector valve on mine has 5 but non the less the same. So I can cut the pigtail for the valve plug off and just find those two wires? Can I do that right in the harness or should I run a line to the plug from the sending unit?
Old May 9, 2023 | 10:55 AM
Franklin2's Avatar
Franklin2
No need to run any wires, if everything is factory and plugged in at the tank, then everything you need is right there at the old valve. The wire going to the gauge in the cluster is there, the wire going to the rear sender is there, as well as the wire for the front tank sender, and some wires from the dash switch to switch the tanks.
Old May 9, 2023 | 04:37 PM
Boneshaker95
5th Gear
Thumbs up
Ok perfect, thanks for the clarity! I should be good to go then.
JWray707
Mar 7, 2023 07:41 PM
Christopher Workman
Apr 12, 2018 01:29 PM
jkart
Sep 9, 2014 07:43 PM
carter442
Nov 6, 2008 08:52 PM
flyhound
Jan 1, 2006 11:17 AM
