stuck spindle
Old May 6, 2023 | 08:54 PM
rich1785's Avatar
rich1785
stuck spindle
What is the best way to get a 25+ year stuck front spindle loose without destroying something? It's off my 85 bullnose F350, anyone's guess when the last time it was off.
Old May 7, 2023 | 04:28 PM
mechmagcn's Avatar
mechmagcn
Need just a little more info. 2WD or 4WD? And is it the ball joints stuck or.....?
Old May 7, 2023 | 06:10 PM
tjc transport's Avatar
tjc transport
i ain't rite
agreed. what is stuck and where?
"stuck spindle" don't really tell us much.
Old May 7, 2023 | 09:22 PM
rich1785's Avatar
rich1785
sorry, 4X4, it's the spindle that you have to remove to get to the ball joints and remove the axle.
Old May 7, 2023 | 10:04 PM
mechmagcn's Avatar
mechmagcn
Looks like you've already threaded the nuts back on, just lay a block of wood on the nuts and wack it with a big hammer.
Old May 8, 2023 | 06:07 AM
Dieselamour's Avatar
Dieselamour
I would use a ballpeen hammer and strike the flange between the studs. If you hammer on the spindle, nuts use a brass hammer or wood and be careful not to damage the spindle. It looks like the surface is deformed in two places
. Check the inner surface where the seal rides to make sure it's not sharp which could damage your seal.
Old May 8, 2023 | 07:22 AM
tjc transport
i ain't rite
i agree. a combination of heat on the surface between the studs, a 5 pound lump hammer, and penetrating oil should break it free.
although i have had to also use a thin flat chisel between the spindle and mounting surface on a few break them free.
Old May 8, 2023 | 09:02 AM
knottyrope's Avatar
knottyrope
grab a 10 lb slide hammer
i used a 5 lb and took 200+ whacks each side
its a pain but take some work
Old May 8, 2023 | 10:23 AM
rich1785's Avatar
rich1785
already tapped where you marked with a hammer, no go. tried a blo.ck of wood also on the spindle nuts also no go
Old May 8, 2023 | 10:38 AM
hobohilton's Avatar
hobohilton
Heat, cool, heat , cool, heat, cool.... Rattle with an air gun
Cool with water...
Expand and contract is going to get you some play.
Amazon Amazon
Old May 8, 2023 | 03:02 PM
rich1785's Avatar
rich1785
rubber boot/seal?
Got it off, heat, and puller helped. what boot or seal is this? The needle baring seal? The manual shows to seals in there.
Old May 8, 2023 | 04:55 PM
tjc transport
i ain't rite
that looks like the axle seal.
keeps crap out of the spindle.
merlynr
Jan 28, 2016 07:27 PM
bcaughhorn
Jan 25, 2016 08:31 PM
spectre
28
Dec 22, 2012 03:54 PM
johnstoys2
Jul 18, 2010 07:24 PM
