Hello everyone, I am swapping out my old rotted out vacuum lines and need some guidance. A lot of them are very fragile and/or already broken...so I'm having trouble tracing them. And the sticker is faded and kinda confusing.
Truck is a '90 Bronco with a 302.
if some of y'all would be so kind as to post some pics of what its supposed to look like that would be helpfull.
Attached pics are of my diagram and a broken line under the throttle body that I'm not sure where it goes.
what does the highlighted part of the diagram represent?
Thanks!
Thanks!
I looked at my '88 Bronco w/ 5L EFI.
This looks like one of the two lines that connect to each venturi (left side) of the throttle body.
These 2 lines T into one and that lines run over to the Fuel Vapor recapture tub just under the battery tray (Front right of engine compartment)
Thanks!
I agree. That appears to be the fuel vapor line. That should be showing the connector for the two parts of the vacuum lines.
