Do Dump Bodies Less Than 96" Width Exist?
Old May 4, 2023 | 07:03 PM
Folgers's Avatar
Folgers
4wd Low
Hi, I have a SRW F350 which is 80" width. I would like the landscape dump body to match the width of the cab but I can only find 96" wide bodies; these line up with a dually cab
I am trying to stay as narrow as possible as I need navigate and park on some tricky city streets
Old May 4, 2023 | 08:17 PM
OverheadCram's Avatar
OverheadCram
Dump insert or dumping flatbed for a SRW. Plenty of dump insert to choose from but they dont fit much. Very few dumping flatbeds for a SRW that im aware of and they are all aluminum, very expensive, and cant handle more than brush, leaves, and grass.
Old May 4, 2023 | 08:34 PM
Folgers's Avatar
Folgers
4wd Low
thanks. I want to avoid an insert if possible. I was hoping for a landscape dump bed 80” width to match the SRW width.
it’s going to have a leaf topper for a trailered debris loader
Old May 4, 2023 | 08:37 PM
GpGuy84's Avatar
GpGuy84
There is a guy near me who has the set up your describing. F350 SRW with a narrow dump body. It looks like a regular dually dump body but narrower. You almost wouldn't notice. I forget what brand they are.
But keep in mind most dually dumps are CC trucks with straight/narrow frame rails vs the crazy pickup chassis... Mating the hoist and body supports would be interesting. Now that I think about it I want to look at the local guys set up again...
Old May 5, 2023 | 02:20 AM
Squanto's Avatar
Squanto
Anything can be made if you want it bad enough.
Old May 5, 2023 | 08:38 AM
Folgers's Avatar
Folgers
4wd Low
nice but was hoping for an off the shelf solution besides an insert that would line up with a SRW truck
Old May 5, 2023 | 09:13 AM
speedfreak78's Avatar
speedfreak78
The problem you're gonna run into is even a narrow steel bed is going to use up most of, if not all, the load capacity on a SRW, that's why the ones that are available are smaller and aluminum. No manufacturer is going to sell something like that for liability reasons. You're probably looking at a custom unit or a used bed and having it narrowed if that's what you need.
Old May 5, 2023 | 09:19 AM
Folgers's Avatar
Folgers
4wd Low
I want aluminum. I’m adding a leaf topper to the dump body and just hauling leaves loaded from a trailered debris loader. Can you point me to an on the shelf 80” aluminum dump landscape bed ? They’re all 96” I can see.
Don’t want insert.
Old May 5, 2023 | 10:02 AM
speedfreak78
Got a picture of what style you're actually looking for? I've heard people call different bodies "landscape". Because you're doing leaves I'm assuming something like this?
https://www.google.com/url?sa=i&url=...r4kDegUIARCWAg
Have you called any local bed builders and talked to them? Most of them will make modifications to their standard models and build what you want, like that place.
Old May 5, 2023 | 10:18 AM
Folgers's Avatar
Folgers
4wd Low
Scroll down to bottom of page for pics. They are all dumps
https://eloquip.com/product-lines/al...e-dump-bodies/
Old May 5, 2023 | 10:39 AM
morehouse7's Avatar
morehouse7
https://martintruckbodies.com/dumping-mp-bodies/
My uncle had one from these guys on his 03' 350 dually dump when the original rotted away. Very well built with quality material.
Old May 5, 2023 | 10:52 AM
Folgers's Avatar
Folgers
4wd Low
Thank you. I see they do an 80 wide.
Old May 5, 2023 | 03:54 PM
Sox3's Avatar
Sox3
Check out alumline.com.
they have aluminum landscaper dump bodies.
Old May 6, 2023 | 07:54 AM
OverheadCram
I have used TruckCraft before. They have a complete aluminum insert with leaf topper off the shelf. The only other option they have for a single rear wheel that is not an insert is an aluminum dumping flatbed. You would have to build your own insert on the flatbed as they dont offer any off the shelf options.
I ran a 9yd leaf box on an F350 for a while. Unless the leaves were bone dry and powder the weight would add up. Truck was on the bumpstops most days before even being full.
bigsashat
Nov 18, 2019 07:13 PM
bxracer927
Apr 27, 2013 03:57 PM
aluv
May 8, 2012 03:18 PM
huskyboy_scott
Apr 30, 2008 05:35 PM
cdrmckinneybb63
Mar 7, 2005 11:29 AM
