CJ-MEA
Old May 3, 2023 | 07:48 AM
DieselDog409's Avatar
DieselDog409
CJ-MEA
Hey do any of you know if my ford big block engine is a cobra jet? It says CJ-MEA on the side of it. I need to know weather or not to scrap it.
DieselDog409
it is just the block and crank
Old May 3, 2023 | 11:51 AM
66F250_4x4's Avatar
66F250_4x4
You are possibly reading the numbers wrong – they can be pretty hard to decipher sometimes. Generally, C would be followed by a number, such as C5 or C9. These would mean 1965 and 1969.
You might be looking at C9VE-A for instance, which according to this website is a 1969 429/460 block. I would look again at your numbers and look at this website and see if anything lines-up.
https://www.enginelabs.com/engine-te...ers-1952-1996/
If it is a 4-bolt main block, it’s a keeper. If it’s a 2-bolt, then I don’t if the block is particularly special to a CobraJet. However I believe there may be nuances to different castings that more knowledgeable folks here can chime in on. I’d post some pictures of the casting numbers and top and bottom side of the block.
Old May 3, 2023 | 12:39 PM
DieselDog409
Ok I will check it out. I wanted to know before i scrap it after school today.
Old May 3, 2023 | 07:41 PM
85e150's Avatar
85e150
You have this in both this forum for 385 series engines and the FE forum. So first I would make sure it's one or the other:
FE block
https://www.mecum.com/lots/275892/fo...-engine-block/
Both here, FE first, 385 about 1/3 down the page.
https://www.diyford.com/how-to-ident...ord-big-block/
A usable FE block, especially one with the bigger bore of the 428, is worth more than the scrap price. Key word: usable.
A 4 bolt 385 block is worth a lot more than scrap price. A 2 bolt is again, probably worth more than scrap,
Old May 4, 2023 | 08:06 AM
manicmechanic007's Avatar
manicmechanic007
The better FE blocks like the CJ? had 4 motor mount bolts
The 427s had the 4 bolts
Junk 360-390s did not have the 4 bolts
Head to intake parting line is under the valve cover on the FE motors
DieselDog409
May 4, 2023 04:19 AM
J Scott
Mar 20, 2018 04:09 PM
t_dickie
General Automotive Discussion
Dec 14, 2004 02:27 PM
