New ICP sensor
Old May 2, 2023 | 07:27 PM
sbraatz's Avatar
sbraatz
New ICP sensor
Just thought it might be time to replacedthe the original ICP sensor with original 302525 miles. It wasn't leaking or anything like and felt to be running just fine. Planing a cross country trip the end of May so not wanting any issues on the road, I changed out the sensor with an Ford sensor from Riffraff. I took it out for a test drive and low and behold it seems to have a bit more pep going through the gears. Noticeably different acceleration. The old girl has got new energy and giddy up. I like it.
Old May 3, 2023 | 07:33 AM
oldbird1965's Avatar
oldbird1965
Winter before last I put in a new CPS, IPR and ICP from riffraft just for the heck of it. When I go cross country I want to be as good as possible. Beside, I have three good spares now.
Old May 3, 2023 | 08:04 PM
96SD's Avatar
96SD
I keep a list of what I have replaced since buying the truck. A list close to that long still needs doing. Neglected, abused, rode hard and put up wet.
Irate efuel
XDP gear reduction starter
Under valve cover harness and gaskets
Glow plugs
Rosewood injectors
Adrenalin HPOP
C&C fab HPOP lines
Rebuilt ZF5 trans
South bend clutch and flywheel
Melling LPOP
Tires
Mitsimoto radiator
Radiator hoses
Riffraff intake boots
Riffraff bellowed up pipes
SPX billet turbo CHRA
Oil log updated oring end plugs
Oil log orings
Oil cooler o rings and gaskets
Stricty diesel oil pan fix
Engine wiring harness
Positive cables
negative cables
Sealed front cover and gaskets
Sealed oil pan
rear main seal
IPR
ICP
CPS
BPS tube and sensor
6637 air filter
power steering pump
Power steering lines
Idler pullys
Harmonic damper
Door skins
Headliner
Diamond eye downpipe
Carrier bearing
Ujoints
Deleted pedistal
Power window motors
Power lock actuators
Door hinges, pins and bushings
CP addict door handle repair
All new fluids
New clutch pedal assembly
clutch master
clutch slave
Brake booster
Exterior side window wipers
Rear bumper
Old May 4, 2023 | 08:06 AM
oldbird1965
WOW!!!!!!!
Old May 4, 2023 | 12:55 PM
sbraatz's Avatar
sbraatz
That is some list!
Old May 4, 2023 | 01:15 PM
96SD's Avatar
96SD
It was his brothers truck who had died so he was emotionally attached to the truck. He kept up with oil changes and front end stuff but didnt have the ability or space to do bigger projects and the labor costs to do what needed to be done were too high. He had just taken it in to the shop to get a quote on getting the trans right and they quoted him over 3K so he decided to sell it. He actually cried and I felt kinda bad. He made me promise to send him pictures as I make progress. I sent him a video and some pictures a few months ago. Made him pretty happy.
Old May 4, 2023 | 01:22 PM
knottyrope's Avatar
knottyrope
i think your ICP was not reading correctly if you have more power now.
usually when they leak oil, a pressure differential take place inside giving off an incorrect reading
Maybe yours was tired from old age
Old May 4, 2023 | 04:14 PM
sbraatz's Avatar
sbraatz
I think we can all say that at some point.
Old May 4, 2023 | 04:28 PM
96SD's Avatar
96SD
Trucks are old, wife is old, dogs are old, I'm old. Too bad I cant just replace my ICP.
Old May 5, 2023 | 08:15 AM
knottyrope's Avatar
knottyrope
You can but then your ICP pressure will build up until you explode
Iantiler
Feb 8, 2023 06:02 PM
RideDiesel88
Jan 28, 2015 07:30 PM
TNT in Round Rock
Jan 24, 2012 03:58 PM
00fordsd
Feb 19, 2011 08:28 AM
